Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: R100 kills batteries
  1. #16
    Feb 2004
    Monroe La.
    Had to go back a look at a wire drawing to see what wire it was. The first time this happen i took the bike to my dealer. He remove the blue wire from the diode board and the amp draw we had showing on the meter was gone. It was not much but after a couple days not riding the voltage was low enough to not start. Have had this happen a couple of times in the 30 years I have had m R65 and R90. Have since upgraded to the 450 watt Omega system about six years ago.
    Don
    1975 R90/6, 1980 and 1982 R65, !959 TR3A Triumph Car
  2. #17
    Well, I think I found it ! I talked to Rick at Motorad Elektrik and he said to check the solenoid first because of the large power drain. When I got in there and took the power from the battery to the solenoid cable off, I noticed that the hose clamp from the (breather vent hose ?) must have cut into the power going out from the solenoid . Mashed the clamp down and taped the cable and moved it a little so it wouldn't happen again. Charged the battery and so far so good.
    Here is the culprit, a sharp clamp end, power cable removed in this picture.
    Thanks so much for everyones help, I really appreciate it !!!!
    ________________________________________
    The early bird might get the worm, but the second mouse gets the cheese.
  3. #18
    Checked the battery yesterday evening, 12.9 , checked this morning....still 12.9
    Back on the road .....
  4. #19
    Mar 2008
    DeLand Florida
    Quote Originally Posted by patiodadio View Post
    Checked the battery yesterday evening, 12.9 , checked this morning....still 21.9
    21.9? We know what you mean. Glad it is fixed, could have been worse, FIRE.
  5. #20
    Oops, fixed the 21.9
  6. #21
    Mar 2010
    Vancouver, B.C. Canada
    That's some good detective work there. Glad you found it!
