Results 1 to 15 of 16
Thread: motul oil
    Apr 2013
    Lat:35.665666 x Lon:118.426980
    motul oil
    I was going to top up between changes and have this quart of Motul 3000. I use BMW oil generally, but didn't want to do a 100 mile trip to the nearest dealer just for a quart of BMW oil.
    Any thoughts, any compatibility issues with the BMW oil? They are both non-synthetic and I don't think that would be a problem anyway. Thanks.
    Marine By Choice #188306
    Sep 2012
    Winlock, WA
    I just did the same thing. Topped off with 1/2 quart and ran 450 miles before servicing at BMW dealer. They said no problem they could think of.
    "Dad, can I get a motorcycle when I grow up?"
    "Son, you can't do both."
    Administrator 20774's Avatar
    Mixing oils in great quantities would create problems I think...different additives reacting in different ways. Small amounts, probably not such a big deal. Remember clean oil is better than dirty oil, and dirty oil is better than no oil.
    As far as I can tell from looking in a fair amount of places, all mineral and synthetic engine oil is compatible with all mineral and synthetic engine oil. That includes semi synthetic oil. The only exception, that I know of, is Castrol R which is not mineral or synthetic but made from plants (and thus not actually an exception). It used to smell great when used in two strokes. The only real problem is using auto oil in motorcycles with wet clutches, which doesn't include airheads.
    61 Gold Star, '13 690 Duke, '13 Daytona 675R, '14 Street Triple R (gone but not forgotten: '76 R75/6, '84 R100, '76 R90S)
    This has been discussed before, but what do you consider "topping up"? Most people have reported that always bringing the oil level up to say the full mark only ensures that most of the added amount will just be "thrown off" anyway. Keeping the oil volume to the full mark lessens the air volume inside the engine and increase the tendency for the oil to be whipped up into a mist which goes out the breather. Leaving the oil around 1/2 stick might be a good compromise.
    Took me years to figure that out with my first airhead.
    Dee G flymymbz's Avatar
    Nov 2006
    Central WA
    My Guzzi's use 10W-60 Motorex synthetic. Always had a half quart leftover. I would mix that with a qt of Honda 10-30 when I'd change the oil in the Honda Rebel. 30,000 miles on the Rebel now, no problems.
    Too damn many bikes to list
    Apr 2013
    Quote Originally Posted by flymymbz View Post
    Yeah, I did a lot research and concluded that there aren't any compatibility issues. The Motul oil is SG rated and should be fine for top off between changes. Cheers.
    Apr 2008
    Portland,OR
    Oil Brands?
    I will usually leave that oil level about 1/8" below the full mark. And have mixed brands before. I would assume that if the oil meets the same API spec's., there should be no problem. Although my BMW riding partner raised his Germanic eyebrow when I once poured YamaLube into that Teutonic engine. At least they were both members of the Axis powers in WW2. Could probably even use Ducati or Guzzi oil in them.
    Registered User b25bsaboy's Avatar
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by chunk View Post
    Chuck, Just catching up on some of the threads and you didn't say what year or model of an Airhead?Reason I ask is that can make a huge difference on what type of oils you may or may not want to utilize.
    Rick MacPherson
    Success is Not a Destination, But a Journey.
    Accredited Motorcycle Appraiser
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    The R90S ran great with Yamalube 10w-50 semi-synthetic. The only reason it has something else now is that my riding buddy left his position as the parts dept. manager at a big four motorcycle dealer.
    Quote Originally Posted by 51456 View Post
    Apr 2013
    Quote Originally Posted by b25bsaboy View Post
    1976 r75/6..... Chunk.
    I wondered why my French fries tasted funny...
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    For airheads, I believe you specifically need to look for the "SG" rating, for the desired quantity of, and mix of, ZDDP.
    Aside from that - shouldn't be an issue.
    https://www.motul.com/us/en-US/produ...iscosity%5D=27
    A quip from a gal when I put Honda oil in her Harley - "Thinning the soup, boss?"
    MOA,RA,ABC,NEF,MCPR,MOAL brownie's Avatar
    Oct 2003
    Pensacola, FL
    Thumbs up Airhead dipstick reading
    I think most of the gurus will say warm oil level is good about 1/4" below full, on kickstand....no??
    Words to Ride by: Patience, Anticipate, Paranoia
    Shep Brown MOA 27510
    "Igor" 82 RS "Inga" 04RT
    Pensacola, Flairider
