Results 1 to 2 of 2
Thread: Need to shorten GS shift lever
    Fairview, NC
    I just installed a Wunderlich engine guard and the aftermarket shift lever on my 02 GS is too long. I installed a Wunderlich peg lowering kit and the longer shift lever that came with it hits the guard. I had to cut out 1.25" of the main tube area. I need help in knowing if a butt weld will suffice for the repair, or will some kind of internal insert be needed? I'm assuming the lever is stainless. I have no knowledge on welding. I plan on taking it to a welder Monday.
    Thanks,
    Doug
    Registered User Bones's Avatar
    May 2003
    Newport News, Va.
    I would contact the aftermarket shift lever Manufacturer and tell them the problem. they probaly have a solution. Remember, the more stuff you add or change, the more problems.
    good Luck! Bones
    Life without Daring Adventure is not worth Living!
    BONES
