Results 1 to 6 of 6
Thread: SMH-10 Battery Life
    Registered User sickticket's Avatar
    Oct 2012
    Dublin, Pa
    SMH-10 Battery Life
    My set up: 2013 R1200RT, C3 helmet, SMH-10 communications.
    My last long ride the Sena battery lasted almost 6 hrs then I got the "good by".
    Is there some way to plug the system into the bike to keep the unit charging and still have the Sena run???
    I plan on doing the SS1000 and would really like to have sound all the time and not have to rely on turning on bikes speakers.
    Thanks you in advance.
    Peter
    Sep 2010
    Hiawassee, GA
    plug in SENA
    Yes, you should have gotten a cord with a plug that you can use on the bike although you may need the adapter. My battery is usually good for about 10 hours on intercom time and a little less if I'm listening to music.
    Mary
    2007 R1200RT, gone
    2009 R1200RT, gone
    2014 R1200RTW, GREAT
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    Your battery should last around 10 hours. The Sena can be charged while riding if you have a receptacle for the charger. I have a cigarette lighter in the speaker grill on my 05 RT that lets me charge on the fly.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    Oct 2012
    Dublin, Pa
    Thanks for the info. I don't have a cig lighter socket but I do have the power socket below the sound system control. Can I use that?
    Quote Originally Posted by sickticket View Post
    You will need the Powerlet adapter that converts that to a cig lighter...it sticks out too far in some applications however.It isn't hard to add a fused cig adapter into a tankbag as well.
    http://www.powerlet.com/products
    Steve Henson
    Apr 2007
    SAT - LAX
    I use the Miccus Chargeblock for charging my iPhone, Bluetooth dongle and my Sena if necessary. It should fit right into the Powerlet Cigarette Adapter.
    SABMWRA MOA #62
    2005 BMW R1200RT
