Results 1 to 4 of 4
Thread: 2002 K1200RS-Steering Damper Replacment Tricks
    B Reams brook.reams's Avatar
    Jan 2007
    Arvada, Colorado
    Folks,
    My good friend wants to replace the steering damper on his 2002 K1200RS. I briefly looked at it and it wasn't clear how to remove the end of the damper that attaches to the fork brace.
    The part in question is #1 in this Fiche.
    http://www.maxbmwmotorcycles.com/fic...png?v=04282014
    What wasn't clear was how to remove the bolt #6. Does it pass through the bottom of the fork brace?
    So, what is the procedure for replacing it?
    Any "gotchas"?
    Any "tricks"?
    Thanks for any advice.
    Best.
    Brook Reams.
    Brook Reams - Arvada, CO
    Endeavor to Persevere
    Various Two-wheeled Vices, All BMW
    2004 R1150-RS||2002 F650-GS||1983 R100RS||1977 R100RS||1975 R75/6||1973 R75/5
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Its a Torx T-30. A pain to remove. The PO of my 99 K12RS tried to remove it a chewed it up pretty bad; and since the damper was ok I left it as is. I have heard heating it with a torch might make it easier. Remove the F wheel and make sure the bike is secure before you tackle it.
    Good luck!
    JP
    If life throws you a curve; lean into it.
    Jan 2007
    Arvada, Colorado
    Quote Originally Posted by 61996 View Post
    Good luck!
    JP
    JP,
    Thanks. It sounds like there is locktite on the threads.
    Best,
    Brook.
    Jun 2007
    My understanding is that YES, there is a threadlock, equal to Red as I recall. Heat, impact wrench, etc. And still some have ended up stripping and having to drill. Good luck.
    Jim Douglas '00 K1200RS >137,000 miles -- owned since new,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
