Results 1 to 13 of 13
Thread: LH Switch Cluster
    Jan 2008
    HBuntsville Al
    LH Switch Cluster
    Looks like my LH switch just died. No horn, windshield wont lower and right turn wont work. Bike only has 1500 miles. Start button on the other side is acting up too.
    My problem is a live 100 miles from the closest dealer and dont want to drive that far with no horn. Anyone taken the LH cluster off? What size are the two screws and how do you take it off.
    My hope is the dealer will send me one.
    Albuquerque, NM
    Dealer needs to install in order to collect reimbursement for warranty.
    If your bike is this new and still under warranty, dealer will send truck to pick up your bike. BMW roadside assistance.
    Kent Christensen
    21482
    Spring Lake NJ, USA
    Quote Originally Posted by caddss View Post
    It might be a tad helpful if we knew what year/model you have.. there are different switch designs on different years. Given you have problems with components controlled by both switches I rather doubt that the root cause is bad switches. The new ones do go bad - but haven't heard of simultaneous failures of both.
    Jan 2008
    HBuntsville Al
    Sorry. It is a 2012 r1200rt.
    Jan 2008
    HBuntsville Al
    Good to know about them coming to pick it up. Will call them Monday. Thanks.
    Registered User wvpc's Avatar
    Dec 2009
    Ypsilanti, Michigan
    Do you ride alot in the rain/park outside uncovered? 1500 miles is not much on a 2012 rt.
    12 R1200 RT
    83 R100 RT
    Sep 2006
    Or spray high pressure at the car wash?
    Steve Henson
    Albuquerque, NM
    You're correct it's a safety issue to have no horn. ... or turn signals nor ability to flash headlight. Given the 2014 shock issue, dealers should be pretty safety conscious and shouldn't refuse you. Those bikes will be transported by roadside assistance and there's no reason yours shouldn't be too.
    Kent Christensen
    21482
    Registered User vetsurginc's Avatar
    Apr 2005
    Parkland, FL
    Quote Originally Posted by wvpc View Post
    My left cluster also just took a partial dump. Started after spending a night in a north florida rain on the way to the RA at Birmingham. Cover was on, but is not waterproof (out of sight out of mind cover from Aerostitch). Started with intermittent turn signal turn off failure (though using emergency flasher and off would stop turn flasher, or let them time out). When I got home tried wd40 to expel any water, but no help.
    Dealer says switchgear is toast and cost to replace around $360. With 4 years and 18000 miles on the clock this is on my dime. Stupid new style turn signals
    Jan 2008
    HBuntsville Al
    Now it works????
    No water involved - rain or wash. Bike is garaged. As for the low miles the guy who had it before me had some medical issues and didnt get to ride much. 1000 miles when I bought it a few weeks ago.
    So today i go to the garage and try the switch and everything works. The only thing I can think of that may have caused the problem yesterday was that when I was riding yesterday I stopped for a while and the bike was sitting in the sun. It was about 85+ here yesterday. Wonder if the sun light coming through the windshields like a magnifying glass could cause the problem.
    Now I'm concerned about taking a trip. Would hate to get stuck somewhere.
    It's under warranty, have it replaced.
    Don't take NO for an answer.
    Australia N,S,W
    Mid North Coast
    2014 R1200RT LC/SE
    Dec 2011
    Menlo Park, CA
    There was some discussion either here or on another forum about being able to temporarily resurrect a hot switch by placing an ice-pack on it, but Alfred is right: get it replaced with the redesigned unit and be able to forget about it.
    JayJay
    '09 R1200 RT, '73 R75/5 Toaster (under rehabilitation)
    Lots of rice burners in the past ...
    Jun 2014
    Canada
    i'd be tempted to carry a small can of freeze spray with me like I use at the shop...
    does anyone happen to know if the '13RT has the old switches or the new part # "upgraded" switches?
