Results 1 to 2 of 2
Thread: R75/5 Leaking fork tube at fork brace
    Registered User JB1982RT's Avatar
    Jul 2003
    South Carolina
    Has anyone repaired a fork oil leak at fork brace bolts ?
    Thread is stripped in fork tube.
    Can not find M13 Helicoil kit.
    Any suggestions?
    1973 R75/5
    1982 R100RT
    Jul 2003
    South Carolina
    Just looked at fische.
    The stud is M8 x25.
    I also see on the picture of the SS stud that the thread lengths are not the same on either side of the center non-threaded portion.
    Probably why I stripped it in an attempt to have the same amount of thread showing through the nut when installed.
    I think they make M8 heilicoils.
    I still wonder if I will get a good seal when the helicoil is set. I suppose red Locktite will do the trick.
    1973 R75/5
    1982 R100RT
