Results 1 to 8 of 8
Thread: ON magazine with starter cleaning article?
    Matt Norton smnort's Avatar
    Sep 2008
    Cheektowaga, NY
    Anyone remember what month the article for the starter cleaning / maintenance on a 1150 was?
    I put that months magazine somewhere so I can reference the article when I got to the project - now I have no clue where it is
    Hopping someone can recall what month the article is so I can get a copy from a member in my club
    Anyone recall?
    Here's a link to a thread on advrider.com where a guy strips down a starter. You might search there, here, and on ukgser.com as well.
    http://www.advrider.com/forums/showt...hlight=starter
    It's a real shame and failure that every article Paul Glaves and Matthew Parkhouse ever wrote is not available at the click of a mouse to BMWMOA members.
    Albuquerque, NM
    Not free to nonmembers
    Kent Christensen
    21482
    Quote Originally Posted by smnort View Post
    Anyone recall?
    It was the first part of the column in the February, 2014 ON
    Here is what it said:
    "OILHEAD STARTERS: These starters often emit a screech just as the starter button is released. Almost always the noise is coming from the one-way clutch built into the nose drive of the starter. Once the starter is removed the round silver disk visible just behind the nose gear is the one-way clutch. There is a visible seam on the forward face of the clutch. To eliminate the screech I clean the starter drive and clutch. I use electric motor cleaner available at any good auto parts store for this purpose. I first clean the entire visible portion of the starter drive with cleaner and compressed air. I then support the starter nose up and spray cleaner right into the seam on the starter clutch. A few squirts followed by compressed air cleans the clutch and the screech will go away for ten or twenty thousand miles. Then it is time to repeat the process. While I have the starter removed and in the vertical position I always also place a few drops of light machine oil where the shaft is located in the nose bushing. I allow a few minutes for the oil to seep down into the shaft bushing interface and then reinstall the starter."
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    '08 BMW R1200RT
    '75 Red R75/6
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
    Quote Originally Posted by gsbruce View Post
    I recently discovered that the whole ON magazine can be downloaded as a pdf file. There are a number of past issues available. The method to find the issue desired and download it is definitely not straightforward. In another thread I created some detailed instructions on how to find and download the ON as a pdf. That thread link is below - look for post #12 in that thread -
    http://forums.bmwmoa.org/showthread....RS-brake-lines
    Quote Originally Posted by robsryder View Post
    This process for downloading archived articles does not work on an iPad. Thanks for describing the arcane ritual that must be performed on a PC to download entire older issues so one can view about 3-5 pages from an issue. I'm going to try to download and edit them down (delete pages in Acrobat) to the oilhead technical articles if possible, if that doesn't work I'll just print those pages for future reference.
    Oilhead Starter Replacement
    I had the same problem. Two years ago I found a new replacement starter for my 1999 R1100RT from Discount Starter & Alternator for $72 delivered to my house (http://www.discountstarterandalternator.com). It matched up perfectly and still works great after almost 2 years. I still have my original, so I will do the clean and lube fix and keep it for possible future use.
