Results 1 to 11 of 11
Thread: R1150rt Oil Leak
    SAY 1 Let's ride ayaple's Avatar
    Apr 2006
    Finger Lakes Region N.Y.
    R1150rt Oil Leak
    I just had my 2004 rt starter motor replaced by a BMW dealer. After 200 miles oil is leaking from the area of the new starter
    dripping on the side stand and blowing back on the catalytic converter as I ride. Is there a gasket that could have failed. The bike never leaked a drop before.
    Any Ideas before I send it back to the dealer
    Art: bikes
    '04 R1150 RT Mine
    '00 R1100 RT Hers
    Registered Schmoozer irish's Avatar
    Oct 2009
    Madison, WI
    Hmmmm, no replies yet so I will chime in. I don't know what WOULD be leaking oil from that area but I would consider things other than the starter motor installation. I've removed the starter motor in my 2002 RT twice and there are no gaskets or oil involved. In fact, as far as I can tell you should be able to run the bike with the starter motor removed and not have oil leakage. With the starter motor removed you can see the flywheel but nothing that should have oil on it.
    I'm not sure what would cause an oil leak from that location and I supposed it's possible your dealer disturbed something else when they did the maintenance. Are you having clutch issues at all? My bike had a slave cylinder failure and that leaked clutch fluid onto the clutch friction surfaces. Maybe that is the source of the leak?
    Please let us know when you figured out what is going on and good luck!
    02 R1150RT
    Registered User RapidRoadRescue's Avatar
    Feb 2012
    Indian Creek, IL 60061 (AKA Vernon Hills, IL)
    We need pictures, there is no oil behind starter motor.
    Use engine degreeser to clean off all oil, then run the bike to pin point the leak.
    The guy who invented the first wheel was an idiot. Now, the guy who invented the second wheel... he was the genius.
    www.motorcycleworkshop.net
    www.rapidroadrescue.com
    Feb 2005
    Trinity, NC
    Quote Originally Posted by ayaple View Post
    The oil pressure sender is in that general area. It's possible the sender got hit and is now leaking. If that's what it is the dealer will likely say that it's coincidental that the sender is leaking. The sender is not expensive and can easily be replaced, but I would first check to see if that where the leak is and then bring it back to the dealer and ask them to fix what got disturbed when they were working on your bike.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Feb 2012
    I seen few timing chain tenssioner leak, or the round cam covers on the back of the cyl head.
    Registered User ratze's Avatar
    Feb 2013
    US, EAST TNN.
    Airbox plug,,,
    The pursuit of reality at all cost.
    Mar 2013
    Winnipeg, MB, Canada
    I'm gonna go with the crappy oil pressure sender.
    I just changed my second oil pressure sensor in two years. I replaced the original with OE and it started leaking so I've gone aftermarket. It's a horrible chore to find the leak with the tupperware on and the damn thing makes your bike look like the Valdez after a good boo.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    Feb 2013
    US, EAST TNN.
    Thats my vote to, ive changed about 3 or 4 of the sencors out on the ole guzzi. cant remember if they wer magnetti or bosch but never the less they wer leaky. the reason i mention airbox plug is that just recently(while on the road) my buddy changed out a faulty starter on his 03 1150 and while doing so he knocked out his airbox plug, after the oil was cleaned up the first time no more evidence of any more leak. he still cant find that plug and we have another 5k ta go.
    Apr 2006
    Thanks for all your input. I called my dealer and they said it must be somthing they did a with less than 300 miles since they did the work. They are sending a truck to pick up the bike (200 miles each way). I will let you know how things turn out. It may be a couple of weeks turn around, Good thing my wife's R1100rt is in good running order.
    Art: bikes
    '04 R1150 RT Mine
    '00 R1100 RT Hers
    RD'nNH&AZ rdhudson's Avatar
    Apr 2012
    Summer in Lakes Region of NH and winter in the Sonoran Desert of AZ
    Great to hear the dealer's thoughts, it may not be their fault in the end. Coincidences do happen but..... It is a shame to think the bike will be out of use for that long. So often we read that dealers are "not responsible" and unresponsive so a post that shows they can be (and in my experience always have been) reasonable is good to hear. I use them after I have tried my damnedest with the help here, to fix it, but when that fails.....
    2002 F650GS, 1998 R1100R 75th anniversary edition, 1983 R80RT (just sold), 1959 R60 (in restoration), Honda CT90
    If you must make a mistake, make a new one each time.
    Apr 2006
    Follow up on oil leak
    The valve tensioner was replaced at the same time as the starter motor and that was the problem. My BMW dealer did pick up the bike and fixed the problem no charge. I didn't want to wait a few more days for them to transport the bike back, so my wife drove me up and I had a great ride back from the Albany , Troy area.
    Art: bikes
    '04 R1150 RT Mine
    '00 R1100 RT Hers
