Results 1 to 6 of 6
Thread: 1994 K75S Front Wheel Bearing
    I need some help locating the front wheel bearing for the 3 spoke K75S Wheel. Part # ? Vendor?
    Expect The Unexpected
    36 31 1 450 859 GROOVED BALL BEARING - 25X47X12 $19.10
    36 31 2 311 030 ANGULAR CONTACT BALL BEARING,RADIAL - 25X47X16 $60.48
    36312311030 was superseded by 36312311031.
    You need one of each.
    Mar 2013
    Winnipeg, MB, Canada
    I knocked mine out and took them to a bearing house. They matched them from the little tiny numbers you can't read. They weren't from a country that now owns Hong Kong and had a good name on them. Fit fine.
    Bought the rear end bearing and seal set the same way. Freakazoid gear set was BMW, ouch.
    Quote Originally Posted by dieselyoda View Post
    Having a machine shop background, I also always check with a bearing house (Bearing
    distributors (BDI) and many others).
    However, I have found that sometime Max's is cheaper! Other times the bearing houses are cheaper. On seals, every time I have checked, Max's has been best.
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
    Thanks to all! Ordered from Max
    Gentlemen of the forum. Is this 2 piece bearing removal and replacement better trusted to someone with deja vu on this ?
    Step by step guide to insure a successful job of removal and replacement?
    I don't want to screw this up
