Results 1 to 6 of 6
Thread: 1994 K75S Front Wheel Bearing
    Slipster Slipster's Avatar
    Jun 2012
    Broken Arrow, OK
    I need some help locating the front wheel bearing for the 3 spoke K75S Wheel. Part # ? Vendor?
    Expect The Unexpected
    36 31 1 450 859 GROOVED BALL BEARING - 25X47X12 $19.10
    36 31 2 311 030 ANGULAR CONTACT BALL BEARING,RADIAL - 25X47X16 $60.48
    36312311030 was superseded by 36312311031.
    You need one of each.
    Mar 2013
    Winnipeg, MB, Canada
    I knocked mine out and took them to a bearing house. They matched them from the little tiny numbers you can't read. They weren't from a country that now owns Hong Kong and had a good name on them. Fit fine.
    Bought the rear end bearing and seal set the same way. Freakazoid gear set was BMW, ouch.
    3xR90/6, one running most excellent, two for restoration.
    1983(?) K100RS for winter project, 1986 K75S(the beutch)sold, 1993 K1100RS (blown engine)sold,
    Dec 2012
    Quote Originally Posted by dieselyoda View Post
    Having a machine shop background, I also always check with a bearing house (Bearing
    distributors (BDI) and many others).
    However, I have found that sometime Max's is cheaper! Other times the bearing houses are cheaper. On seals, every time I have checked, Max's has been best.
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
    Jun 2012
    Broken Arrow, OK
    Thanks to all! Ordered from Max
    Jun 2012
    Broken Arrow, OK
    Gentlemen of the forum. Is this 2 piece bearing removal and replacement better trusted to someone with deja vu on this ?
    Step by step guide to insure a successful job of removal and replacement?
    I don't want to screw this up
