Results 1 to 6 of 6
Thread: TPMS sensor installation?
    Nibley, UT USA
    Installing a tpms sensor in a spare rear wheel. Should the sensor body extend toward the front or the rear of the bike once the wheel is mounted? Or does it not matter?
    Thx
    DG
    DGerber
    1983 R80ST -- 1988 K100RS (r.i.p.) -- 1995 R1100RSL (gone, never forgotten) -- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    Jun 2007
    Ten days and no other replies...I don't recall which direction mine were when I changed tires on the K13S, but I don't see how it would matter. Centripital forces will throw it to the rim, but I don't see there would be much shear either in acceleration or deceleration, or not enough for it to matter which direction the mass was...and you have likely already gone one way or the other, right?
    My recollection from other threads, and this may be incorrect, is that the sender has to be recognized by the receiver and that that takes setting by the dealer.
    Jim Douglas '00 K1200RS >135,000 miles my primary bike again,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    Nibley, UT USA
    Quote Originally Posted by 58058D View Post
    Thanks, pretty much that was my assumption. There is a picture in the service CD, but no annotation as to whether or not the direction matters. Time will tell...
    And yes, the onboard brain needs to be told to recognize the new sensor, or more correctly the new "set" of sensors--which in my case is a different rear sensor coupled with the same front sensor.
    Best,
    DG
    DGerber
    May 2007
    Raleigh, NC
    Quote Originally Posted by GTRider View Post
    Will the CPU remember more than one set of wheels, so that when you change wheels back and forth (as a set) it is good to go? Or will it just remember one set at a time?
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    Debbie's Servant Lee's Avatar
    SW Iowa
    It can also be done with a GS911.
    Lee 2011 K1300S
    MOA # 30878
    Nibley, UT USA
    Quote Originally Posted by roborider View Post
    Yes, it will remember two sets of wheels. After a wheel swap it takes a quarter-mile or so before it registers both of the sensors, but no issues. In my case, it is only the rear wheel being swapped in/out so it just considers the front wheel as part of both sets.
    Best,
    DG
    DGerber
