Results 1 to 6 of 6
Thread: 2010 R1200RT Horn Button Fail,Need Help!
    dchumphrey rthump's Avatar
    Apr 2010
    Wausau, Wi
    I'm looking for some insight on trying to solve the issue of my horn switch fail. First to note I do have an aftermarket horn (Air Cannon bought from Aerostich) I have checked the relay, fuse and I even hot wired the horn to be sure it worked and it does. I also checked the wiring with a volt meter to make sure I had juice to the horn. The only thing I can think of at this point is the switch. Has anyone else had a switch failure and if so was the whole switch replaced or do you know of a way to open the switch housing and check something (connections) in there? Thank you in advance for your input!
    Dave 715-581-1263
    Unfortunately, lots of reported switch failures on the 10-13 RTs. I had my cruise switch fail at about 1000 miles and had the whole left hand switch block replaced, under warranty. I believe BMW updated the switches as a result of the failures. Check with your dealer and if you're under warranty still, you should get the block replaced with the updated hardware.
    "Looks like I picked the wrong week to stop sniffing glue..."
    Current ride: 2012 R1200RT
    MOA #175432, BMW RA #41108
    MSF RiderCoach
    Apr 2010
    Mission, TX
    The above is correct. Majorly bad switch gear on these bikes. I got a 2010 also and had the LH switch gang replaced about 5 times. Now my RH switch is bad.
    I don't know how BMW avoided a recall on these bikes. My dealer is far away so even under warranty it's still a PITA.
    tsp
    My MC Blog:
    http://www.airheadmoto.com
    Apr 2010
    Wausau, Wi
    Well I have a small update. I purchased a GS911 scan tool because I also got the dreaded "Brake Failure" light the other day and wanted to pull the codes to see what is up. So after I scanned I found a fault code for the horn (41739) Horn malfunction, open circuit. Now my thoughts are this is in the switch so I'm going to try and open it up and check it out! I guess if I wreck it I would have to buy a new one anyone for why not mess with it. As far as the brakes looks like the speed sensor has an issue, multiple codes here (24052,23954,23952) First one is an electrical under voltage code, I know I need a new battery. The other are front wheel speed sensor. I will update after I get done with some research.
    Adventurist nakwakto00's Avatar
    Aug 2013
    Olympia, WA
    I got the brake failure light too. Front speed sensor wires were rubbed bare. Re-wrapped and re-routed them and problem was resolved.
    -don
    #161988
    "If you don't treat yourself right, no one else will."
    '06 R1200RT, '13 F800GS, and '16 R1200GSA (wife's)
    Apr 2010
    Wausau, Wi
    Don, I found I had a speed sensor cable that was rubbing on the rotor as well. Took your advice and cleared the code and rode, no light! So, that issue is solved now I just need to fix the horn. I haven't pulled the switch gear apart yet but that is next.
