Results 1 to 7 of 7
Thread: Error light stays on BMW charger...
    Oct 2007
    illinois
    I recently had Hyper-lites installed and Piaa's installed on the fork legs of my 2011 R1200RT, today was the first time i had plugged my BMW battery charger in after having the extra lights installed. When the ignition is turned on the light for the 1/3 power is on, when the key is turned off, within moments the 1/3 light goes off and the error light on the bottom of the charger comes on. Just wondered if anyone else had experienced this issue.
    Ozzie Flyer
    Mar 2010
    Brisbane, Queensland, Australia
    Quote Originally Posted by phoenixrdr View Post
    Where did you connect for power to the Hyperlites?
    regards
    Paul
    Ozzie Flyer
    BE KIND TO HUMANS... THEY BITE
    Oct 2007
    illinois
    Quote Originally Posted by pch123 View Post
    Appears to have been connected at the battery...
    Jul 2007
    THE BIG SKY
    I think all you can do is to try to isolate the source of the problem by systematically disconnecting the new electrical accessories. As you do so keep checking the effect it has on the battery charger. If it causes no change, then reconnect and move on. While doing this procedure also look carefully for any visible damage (evidence of a short, frayed wires, disconnects, etc.) that may have occurred during the recent work. It may also be a fault in the battery.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Oct 2007
    illinois
    Thanks for the advice. when time permits I'll post what was causing the problem,,,
    Oct 2007
    illinois
    Had the lights wired up to a different power source,,
    Sep 2008
    Wilmington, NC
    This issue has been reported previously both for hyperlites and P3s on various model BMWs - the power needs to be sourced so the lights are not seen by the BMW charger.
    Easy fix as noted above. The folks at Hyperlites or Skene who makes the P3s are familiar with issue and know the solutions.
    A cheaper answer is not to buy a BMW charger. Probably 98% of us use some sort of direct to battery connection for charging despite the baseless warning in the Riders Manual. I've yet to hear anyone suffering damage to a bike computer from a power spike passed by a charger, the presumed basis of the warning. The direct connection allows use of any suitable charger at 1/2 - 1/5 the cost of the BMW version plus providing a connection point for other items like heated gear (the factory circuits will not handle heated gear for 2, for example). It also ensures you won't go the garage in the spring and find a bike with a battery dead from parasitic draw and normal discharge because the BMW charger maintaining the battery failed to restart after a brief power interruption, a common event.
