Results 1 to 7 of 7
Thread: 28L Top Case Help
    Aug 2006
    Southern California
    28L Top Case Help
    Hoping someone might chime in...
    I need to rekey the 28L top case and was hoping to find out how to seperate the inner half of the bottom case. The latches are not real smooth in operation and I would have good access to the lock cylinder for the rekeying.
    Has anyone performed the disassembly? Special tools required?
    Thanks in advance.
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    To the best of my knowledge, they are bonded together and won't come apart without breakage.
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    May 2004
    St.Bruno, Quebec
    Quote Originally Posted by lgb View Post
    Thanks in advance.
    Try this link. I rekeyed my topcase by following the instructions
    http://www.ebbo.org/re_keying.php
    johnv
    May 2004
    St.Bruno, Quebec
    Quote Originally Posted by johnv View Post
    johnv
    Sorry, the link doesn't work anymore.
    Johnv
    Registered User bmwed's Avatar
    Mississauga Ont, Canada
    I have it saved as a MHT file. Send me your e-mail and I'll send it to you.
    Regards
    Ed
    Purchased a used 49 ltr top case.. no key...can you please send me a copy of MHT file
    [QUOTE=bmwed;932825]I have it saved as a MHT file. Send me your e-mail and I'll send it to you.
    Regards
    Ed[/QUOTe
    Purchased a used top case with no key. Can anyone tell me if I need to take apart or simply drill out the cylinder ?
    Can you please send me a copy of MHT file. My e-mail address is joe.valentini@metso.com
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Thanks in advance.
    i was successful in taking the lock assembly out of my 49 liter case for re-keying....i believe the 28liter is very similar....and there are some quirky things that need to be done to reassemble so everything works....only took me about 5 tries to get it right...LOL
    i work in Goleta (Santa Barbara) and live in Solvang if i can help...
    wyman
    ~wyman~
    2015 S1000R - Duke - Black Storm Metallic
    2013 R1200RT - Sassy - Fluid Grey Metallic
