Results 1 to 15 of 24
Thread: New Rubber For Old K11LT?
    I've put thousands of miles over this harsh-for-us DC winter and it's time for some new rubber. I want durable and all weather with the quality to handle some 110 mph riding (theoretical, wink). All weather means main ride: wind, rain. Probably need new rubber before winter so for every day, DC streets, long-ride highways, some Iron Butt (Boston, Bloomington, etc), and some twisters. What do you recommend? It's a 1995 K1100LT so pretty heavy, as am I, and sometimes two-up, sometimes with three full hard bags.
    Purple 1995 BMW K1100LT named Pōni with the license plate ICBMW
    Metzeler ME880 Marathon front and rear.
    Thank you!
    Mar 2013
    Winnipeg, MB, Canada
    Is your comment from experience with that tire?
    I'm just curious to find out how you made such a "matter of fact" comment and wondering if I am overlooking that tire. I have an R1100RT with PR3's and it turned it into a different animal than any of the other rubber I have used on that bike and will slam another pair on right away. I have a K1100RS that ran, when it was running, with PR2's but they are smoked and not in a good way so I need rubber for it. My K75S is running Metzeler's and 8,000 kms later, they are in very great shape.
    I don't like the Metzeler for shedding water and it was the same way on my Airheads but other than that, quiet, nice in the corners and the life seems to be atrociously better than the Michelins.
    Just need some opinions and then I can form my own, which sometimes isn't very good.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    I care more about water, rain, & traction than a 10k life. But I don't plan to race (can you imagine?)
    13278
    Apr 2006
    Near Lynchburg, VA
    New Rubber
    Last three rear 880's I had, had splits develope down inside the threads halfway thru their useful life. Last one before 3,000 mi. Talked to others who had the same problems. Bad batch ?
    You don't expect Germans to admit mistakes do you? Ran them for many years. Now, no more Metzelers for me.
    Charlie
    Oct 2011
    Ohio
    I have PR3's on my '93LT and will not go back to the bias ply tires, I have never felt unstable in the wet or cold.
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    Feb 2006
    Long gone
    You won't be disappointed with PR 3's.
    Ride Well
    Registered User tourunigo's Avatar
    Aug 2005
    Larry's River, Nova Scotia, Canada
    1992 k1100lt, two up, packed with small uni-go trailer.
    110/80 ZR 18 FRONT (PR2)
    140/80 ZR 17 REAR (Avon Azaro AV 46-ST
    the switch from bias ply to radial had almost a magical affect. - Bob
    Bob Weber
    saltyfogriders@gmail.com
    Larry's River, Nova Scotia, CANADA
    I ended up getting new Avon RoadRider tiors front and rear. They were my mechanic's recommendation.
    Sent from my Nexus 5 using Tapatalk
    Northern Front Range, CO
    not sure if it's your picture, or your front wheel... but there appear to be some small dings on your front wheel. yes, no? (seen at/near the 3:00 position in first picture)
    Ride Safe, Ride Lots
    It really does look like that, doesn't it. Will look closer today.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Yep, that's a bent wheel. It's very visable in the first and the second picture.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Why didn't he ever mention it? I'll have to ask my mechanic if he had noticed it. Still feels super solid at speed. Could it have been a recent pothole? What sort if impact would have done that?
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The front 3 spoke early K wheels do have a tendency to bend when they hit road hazards as the rim is only supported every 120 degrees. The earlier Y spoke wheels are much more robust, as they are supported every 45 degrees.
    Luckily, the 4valve K100RS and the K1100 wheels are more plentiful and easier to find used than the 3spoke K75 wheels! The 2 valve wheels are not interchangeable with the 4valve wheels due to the 4valve having floating rotors.
    There are a few places that can straighten the wheel including the Motorcycle Frameman in Sacramento, Ca. http://www.motorcycleframeman.com
    I've had EXCELLENT results with him on several people's forks and wheels.
    Mine, Hers, Spare
