Results 1 to 15 of 21
Thread: 83 K75S - Rear Brake Master Cylinder
    During
    1993 K75S Mystic Red Pearl
    2007 K1200GT 997 Blue
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by ghyber View Post
    Is it normal to have some hydraulic fluid in the boot area
    or is that evidence of a small leak from an impending failure of the o-ring on the piston of the master cylinder?
    No. The boot is to keep dirt out, not fluid in.
    Yes. Replace the master cylinder, unless you know how to rebuild it.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Mar 2013
    Winnipeg, MB, Canada
    Yep, replace/rebuild the M/C.
    If you ignore it, you risk loosing residual pressure which means you have to pump the pedal to get firmness. At worst, she just goes and you loose the rear brake.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    Instigator cele0001's Avatar
    Feb 2014
    Jacksonville FL
    I have a similar situation on mine. I took it apart ,cleaned it, rubber looks good. We'll see. Haven't had a chance to test it long term, so far it is ok. It is worth a try
    I want to be unique, just like everybody else.
    Jun 2012
    Olympia, WA
    My rear master cylinder blew up a couple of years ago while I was riding. The brake fluid spray got all over the rear shock piston and destroyed the shock from the inside. Had to replace both the MC and the shock.
    Springfield Mo
    Rear Master Cylinder
    Rear master cylinder on my 90 K75 has been leaking a small amount for the last couple of years. I add a little Dot 4 couple times a year. Bought the rebuild kit last year but have been putting off doing it. The K75 has been moved to 2 Nd. place after buying a used 08 F800ST 2 years ago. K75 has about 153,000 miles on it but only got about 2,000 miles last year. Trying to decide if it's worth doing the rebuild or if when i tear it down I
    will find the bore all pitted and i will have wasted my time & the $75 price of the Kit. Has any one had any
    luck rebuilding one??
    Bill
    Feb 2014
    Jacksonville FL
    Quote Originally Posted by tvbilld View Post
    Bill
    Given how easy it is to open the cylinder it might have been a good idea to look at it before buying the kit.
    Springfield Mo
    Quote Originally Posted by cele0001 View Post
    Hind sight is always 20 20 !!But I usually want to have parts in hand before starting a job. I got motivated enough last Friday that I pulled it apart & Installed the kit. Cylinder had a few shallow pits in it. Will have to see how long it last. Did about a 40 mile test ride. So far no leaks yet. Job only took about 3 Beers to complete.
    Checked on Beemerboneyard web site & they show a new Master cylinder for about $130 some dollars. Showed used ones out of stock.
    Bill
    Feb 2014
    Jacksonville FL
    It is amazing how much you can charge for a couple of pieces of rubber isn't it?
    Hello
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Care to share the "logic" behind the "sitting for a few months will cause brake systems to leak" theory?
    Mine, Hers, Spare
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    So what is the acceptable amount of leakage on YOUR BIKE?
    How does that compare with BMW's recommendation?
    What would be the result of a failure on that particular system?
    A leak is a warning. Will you heed it?
    New brake seals in undamaged bores do not leak, even in cold weather. Worn or damaged seals or bores do.
    Mine, Hers, Spare
    Mar 2013
    That's actaully a very good, dead on answer.
    Most hydraulic systems will leak in the absence of residual pressure. It's usually due to lack of pressure to keep the cup expanded. Shrinkage of the seal, not so much but rather, any seal, requires a fluid film to be effective.
    Brake systems though, I tend to be over cautious and that is just my advice but if if you are comfortable and the machine stops when you need, perhaps I'm being a bit of a Granny.
