Results 1 to 6 of 6
Thread: New top case for an '04 k12gt
    As I plan for some two up trips this year, I'd like to upgrade to a new case that will hold more and be a better back rest for my sweetie. I currently have a saddleman attached to the stock rear rack. Best I can tell it has a limit of about 25lbs. I believe givi has some to choose from with better brackets to allow for more weight. I'd like to be able to carry maybe 35 lbs with a cushion back rest and an additional top rack for a Helen two wheel roll top bag. What options have worked for some others?
    Thanks for your help.
    Tom
    Astatula, FL
    I have a Givi rack holding a fuel cell on my K12RS rig. It's very sturdy and will far surpass your stated load requirements. You can also get some really nice plug & play lighting for some of the Givi cases.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Apr 2012
    Los Angeles, CA
    All the Givi cases I've looked at specify a load limit of 22lbs or less. It's frustrating, as I assume the real number is higher.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Astatula, FL
    Quote Originally Posted by JamesInCA View Post
    I saw that when I bought mine. 'I' consider it lawyer talk, YMMV. The Givi rack is really well built and sturdy, much more so than the factory rack. I know I have more than 22 lbs. on mine, and I'll speculate most people routinely carry more in their Givi topcases.
    Bob Weis
    Apr 2012
    Los Angeles, CA
    I consider it lawyer talk too. And the perverse thing about it is that by putting a sort of obviously lowball number on it (all of them exactly 10kg, what a coincidence!), they're probably encouraging foolish experimentation to figure out where the line is, rather than just saying it.
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    Yep the big Givi works for me and this is years later,AND I am a lawyer.Use your common sense about loading it and check its fastenings from time to time,they do loosen.
    Sometimes,nothing is a real cool hand.
