Results 1 to 6 of 6
Thread: 03 K1200 GT side case rekey
Hybrid View
    Ohio
    I have purchased side cases on Ebay to replace my damaged ones. They came with a key but I would like to swap the lock sets out so that I don't have to use 2 keys. Everything I have seen talks about using a small pick inserted in an access hole inside the case to get to the release tab on the lock set. I don't seem to have that option. Do you put the pick in beside the red colored locking tab for the handles? I have been scratching around in there with a bent paperclip with no luck. I will go buy a bent pick tomorrow if that is what will do the trick. Any help would be greatly appreciated.
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    Registered User trident74's Avatar
    Mar 2006
    northeast Pa
    Jeff, here is a web site that will show you how to re key your bags.
    www.ebbo.org/key.php look for the one for the R1100/1150 there the same bags as yours. You do not really need to buy the kit. You can re arrange the wafers to fit the key. I had to do mine and it wasn't that hard. I have a 03 K12RS.
    Val
    Ohio
    Val,
    Perfect, tells me exactly what to do.
    Thanks,
    Jeff
    93 K1100LT
    Mar 2006
    northeast Pa
    Glad it worked for you. I know what a pain in the ass it can be. I purchased bags for my K12RS off eBay. They arrived with no key. One bag was closed and other bag was open. I couldn't use them that way. I had to get the seller to send his key so that I could use it to re key the bags to my key. I couldn't do anything with them without his key. Good luck. If you need to make the bags look new again, you just need to really clean the bags as best you can. Then wipe them down with alcohol to get wax off and re paint them with Krylon Fusion paint. It is made to bond to plastic. You be surprised at how good a job it will do.
    Val
    Ohio
    The bags I got on ebay were almost like new. The guy selling them said that they were never on the bike. BS as there were a couple of boot scuffs that polished out. Anyway, thanks for the tip on the paint. I hope that I don't need it.
    Jeff
    93 K1100LT
    Registered User 116318's Avatar
    Nov 2005
    Byron Center, Mi
    side case rekey
    I lost a bag off my gs a few years back, bought one off ebay. I live close to a BMW dealer and they redid my lock to match my key in 10 minutes and didn't charge me. Good luck.
