• Welcome Guest! If you are already a member of the BMW MOA, please log in to the forum in the upper right hand corner of this page. Check "Remember Me?" if you wish to stay logged in.
    We hope you enjoy the excellent technical knowledge, event information and discussions that the BMWMOA forum provides. Why not take the time to join the club, so you can enjoy posting on the forum, the club magazine, and all of the discounts and benefits the BMWMOA offers?
    Want to read the MOA monthly magazine for free? Take a 3-month test ride of the magazine; check here for details.
  • NOTE. Some content will be hidden from you. If you want to view all content, you must register for the forum if you are not a member, or if a member, you must be logged in.
Oilhead Newbie
markaz
After riding and wrenching on an airhead (1983 R100RS) for the last couple years, on Thursday I bought a 2004 R1150RT with 22k miles on it. I've been watching the ads for a few months and this one just appeared and was too good to pass up. It's nice and clean and appears to be in great shape. I've put about 50 miles on it so far and am starting to get used to it...it's just a little different from an airhead :). I've also been lurking here for a while and so I think I know what I need to be watching for but any advice from you old timer oilheads would be appreciated. I'm planning to take a couple 100-200 mile rides on it and then put it on the lift and take the fairing off & see how it looks re: fuel line disconnects, cam chain tensioner, etc. and probably pull the starter to check the spline play. It's supposed to have had a spline lube, along with complete fluid change, within the last several hundred miles but I'm a believer in 'trust but verify'. Then there are a few farkles to add...
At any rate, I'm looking forward to some nice two-up touring with my wife.
And I've plotted a route for an Iron Butt '1000 mi in 24 hr' ride... ;)
I just went the other way from 94 RS to a 88 R100RT. I'd be interested in what you think about the differences between the two. The RT made me appreciate the RS more so far though it's only been about a week
I have both, an 81 R100RT and an 03 R1150RT. Be very careful of the power brakes at slow, parking lot speed. Especially when turning and riding two up. I try and use one finger on the front brake during slow riding.
Sudden stops can be scary.
I want to add that there is another excellent web site forum to add to your list. bmwsporttouring.com
In the timeframe of the Oilhead, Euro regulations mandated biodegradable wiring harnesses, and the first attempts weren't so successful. Keep eye on wiring condition. In addition, many here report fairly early failure of brake hoses on Oilheads. Those on my Airhead were good as new I think at 27 years, but Oilheads appear candidates for sooner replacement. My 1100S (puts Airhead RS to shame) was due for system flush and I didn't feel up to DIY, so it got Spieglers at the same time.
Only thing I find scary about whizzy brakes is there aren't any until ignition is switched on. You're probably always in better control of an S as opposed to an RT I expect, making the light touch not so scary is my guess.
Congratulations! A wonderful machine and a great choice! (Yes I'm biased. :thumb)
Definitely go ahead and just R&R the fuel line disconnects; that will save grief down the road. Be prepared to R&R the fuel line inside the tank and the filter on the pump's intake too. Tedious but not difficult.
I believe that by '04 the harness (specifically from the ignition trigger) was updated with better insulation.
I also think that the '04 has better brake lines than earlier ones, but I could be wrong (was there any Official Factory change here, anybody?); if they ever "feel wrong" or there is ANY junk in the fluid when flushed, change 'em out.
Sounds like it just sat for a while; add some Techron and/or Sea Foam to the tank to make sure the injectors are clear.
The cam chain tensioner is optional but worthwhile (my '97 failed here), and reduces start-up clatter. The older tensioner is exactly why one should not goose the throttle at start-up.
PRACTICE with the brakes! Practice with the engine running AND with the key off - know what happens before you actually need it. Brakes are partially linked, so you don't need to touch the rear unless you're on a hill or trail-braking in a curve, or just want to flash the brake light at the guy behind you. Tail & brake lights are pretty small and need additions; many after-market items available.
It had a spline lube at 22,000 miles?? Did the seller have any paperwork for that? Unless he's extremely cautious or paranoid, not many folks go in there for a clutch & spline check at that low mileage...
+ 1 on the 22K spline lube!! Paranoid, but if it's documented WTF?
I loved my 04' RT and still love the 97' RT. Yes, work with the brakes and when you service them ensure you work with the bits under the tank as well. Check your quick disconnects for your fuel lines (under the right side of the tank saddle). You should think about upgrading those to metal before you have problems at a bad time.
Ride safe and go get some pancakes at Joe's Farm Fresh.:eat
The in-tank hoses on my '04rt failed without warning at 27K miles. One minute go, next minute no-go. Highway, lefthand passing lane.
Clean and lube the starter if it hasn't been done and make sure the internal planetary gear cover is secure.
Those things and the need to lube splines were my only surprises, but I still have a spare HES and clutch slave cylinder waiting to be installed.
It will run a lot better richer but ride for a while and then decide.
RB
I'll just say that you're going to really understand and appreciate just how functional the oilhead is after riding it for awhile, then going back to the airhead.
Congrats on the purchase. Now, I'll simply hang up and listen to the true experts on here.
Thanks for all the inputs, guys.
I did about a 60 mile ride today and have to say, it does ride nice at speed, I had it up to about 85 for a short time...nice and smooth. I've never had my airhead that fast. It's definitely smoother and more stable at speed than the airhead. I haven't done any twisties on it yet so don't know how it will compare there. In city traffic it feels bigger and heavier than the airhead (it is!) but again, I think that will improve as I ride it more. I think that the differences will be more apparent when I ride the airhead again after riding the oilhead for a while.
Re: spline lube...the seller had an invoice for a bunch of work done at the local dealer a couple thousand miles ago. Unfortunately, I seem to have left it with her and I don't remember all the details but the spline lube sticks in my mind. It was a fair amount of work (almost $1000 worth) that made me feel better about the maintenance of the bike. She said she would mail me the invoice but I haven't received it yet. The bike was her husband's, who passed away a few months ago and she's moving and has no use for it.
I put in on the lift today and looked it over. I can see the fuel line connectors thru an opening in the fairing and they seem to be metal. One side of each is definitely metal, the other is black but looks like metal. Does that sound right? Are there only two connections?
It also has a Throttlemeister, a taller Cee Bailey windshield (and the original), and those 'highway foot pegs' that attach to the head and fold out. I doubt I will use those so will probably replace them with the stock covers and sell them...they're kinda pricey.
Question...is it necessary to sync the throttle bodies like syncing the carbs on an airhead?
Anyway, so far I'm pleased with the bike. I'm planning to do a couple hundred mile ride tomorrow up into the high country...we'll see how it goes. Stay tuned...
I wouldn't sell those 'highway pegs' if I were you. They are very handy on long trips...heck even handy on short trips! And they look 'stock'. Just a few more bolts to turn when you do spark plug removal.
Synching the throttle bodies is required. They do what the carbs do on an airhead.
The highway pegs are nice to have on long trips, just like the throttlemeister. I'd keep them.
As far as the quick disconnects, I was told by Ted porter at the Beemershop that only the male end breaks. I only replaced the male ends. One could be metal and one could be plastic in that case.
I went with two metal QDs but there is an advantage to leaving the female in place. On the plastic part (female) the plunger is shrouded. On the metal female QD the disconnect plunger sticks up and sometimes is pressed accidentally.
Thanks guys...
Looks like I'm set re: disconnects. I'll check on the tensioner when I take the fairing off for the TB sync.
I found several 'how-to's' for the TB sync (Google is always helpful). I have a TwinMax and am familiar with the process from the airhead so looks like I'm good to go there, too. Just gotta get a round tuit.
I'll give the highway pegs a try but they don't look all that comfortable to me. Never know till you try, tho.
I took the bike on a 200 mile run today up to Payson & back. Wow! I like this bike. A lot. Not any real twisties but lots of high speed sweepers. It feels very secure & stable and seems to be very happy at 75-80 mph.
The seat is not very comfortable, tho. My butt is still kinda sore. And lowered peg & bar risers might be in the future. I'm 6'5" and anything that will help unfold my knees sounds good. I have the seat in the highest position but still it's kinda cramped. Then again, at my height you get used to that, to a point.
Anyway, so far, so good. I'm kinda looking forward to taking off the tupperware and checking it all over. My wife thinks I'm nuts to get a 'new' bike and then take it apart right away. Oh well...
The seat on my bike was custom and only fit in the low position so, not knowing better, I got a Tall/Comfort seat from BMW. Not bad actually. I'm tall too and run the seat all the way up.
I contacted the service guy at the dealer where the work was done on the bike and he said that the 'output shaft seals, clutch slave cylinder and clutch plate' were replaced at 20765 miles (now has 23000). He didn't have any more info on it except that it was done at the end of 2011. So...maybe a leak that oiled the clutch plate? Hopefully not spline wear. I'll check it when I take the fairing off. Just putting it in gear and rocking the rear wheel there does not look to be excessive play, probably less than on my airhead. We'll see...
Sounds like the clutch slave or shaft seal leaked and ruined the clutch plate. Beemerboneyard is a great place to buy parts and they give MOA members a discount. A happy customer and not related etc.
I've really enjoyed mine. So good a ride I haven't been able to let it go. Bought at 32K, now at 60K. Had intermittent low volume horn annunciation. New battery fixed... Had an intermittent kill problem which turned out to be frayed wire at the base of the ingnition switch. Diagnosed here... Had a weird fuel problem, engine bogged and almost wouldn't run. Turned out to be a fuel filter clogged from charcoal, which in turn caused the fuel pump to burst... Was cruising at warp 7 one day, and started to lose power. Barely made it home. Torched exhaust valve, so I had top end rebuilt(diagnosed here)... Started one morning and had no headlights. Commond ground burned through (diagnosed here). Had replaced with a more apropriate piece of wire. Every time I get on it, I forget the issues and just enjoy the ride.
