Results 1 to 14 of 14
Thread: bike miss firing
    Registered User brianfisk's Avatar
    Cromwell CT
    bike miss firing
    Let me start with some history. I broke down last summer, the bike started misfiring,and then stopped. it was the HES. Got it replaced and it ran fine for a few miles. Then started misfiring again. It was thought to be water in the gas. I rode for 2200, each tank of gas it got better and I was able to run the tank almost dry.
    I have since changed the fuel filter and cleaned the tank. I left for Bike week in the cold (13). It ran fine until it warmed up around (55). Which was over500 miles. Then a few misses. Continued getting worse, would run awhile when cold. I decide that I did not need to break down in the boonies so I headed home. It kept getting worse, almost all the time.
    I stopped in a rest area to let it cool off . I also for some reason decided to pull all the relays in the fuse box. 800 miles later it still has not missed once and actually started a bit easier.
    Any ideas? I want to fix this and don't know what to do. I think it it an electric problem.
    Left Coast Rider
    Nov 2011
    What model and year is your bike? Mileage? It'll help those who would like to contribute.
    Instigator cele0001's Avatar
    Feb 2014
    Jacksonville FL
    I would go on a limb and say it wasn't the HES or water in the tank or you pulling out the relays.
    I want to be unique, just like everybody else.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Model, Mileage, last tune up, plug condition etc.
    Give us something to work with here........
    Ufda happens..........
    Cromwell CT
    1999 r 1100rt last tune up 2000 miles now everything done 111,000 miles at that time now 113300
    Feb 2008
    Start with fresh plugs and then the wires if they are original.
    Mar 2013
    Winnipeg, MB, Canada
    Rule of thumb
    Lawnmower, chainsaw, family car, start with plugs.
    Wires are easy. In the dark, spray water on them. If they are an issue, you should see the discharge. It's actually neat to see.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    Feb 2008
    Quote Originally Posted by dieselyoda View Post
    Most of the time yes, but leakage is not always visible.
    At that mileage, it's not a bad idea to replace them if for nothing but PM.
    Mar 2013
    Rule of thumb. YFA.
    Cromwell CT
    plugs&wires
    The plugs were replaced at the time of tune up. Wires were done 20,000 miles or so before. Since Both sides were not firing I ruled them out. Plus the fact that the relays were pulled and bike ran right. That is the direction I believe that I should lean towards. I also mentioned that the bike starts better now.
    Brian
    Mar 2007
    Ambler, PA
    Quote Originally Posted by brianfisk View Post
    .. I stopped in a rest area to let it cool off . I also for some reason decided to pull all the relays in the fuse box. 800 miles later it still has not missed once and actually started a bit easier...
    My '02 R1150RT abruptly stalled and died several times over a 3 year period. When looking at the relays (in desperation) I noticed that one was standing a bit proud of the others, the Motronic Relay. After I pushed it down the bike started and ran fine again.
    I cannot explain it, and none of my guru friends ever heard of such a problem. But it happened at least 3 times to me.
    As superstitious preventive, I put a chunk of styrofoam between relay tops and relay box cover for a couple of years. Since then I've discarded it and the problem has not recurred.
    My bike had seen a lot of rough roads, that vibration is the only thing I can think of.
    Superstition or not, it doesn't hurt to push the relays down when you're stalled at the roadside.
    Doug Raymond,
    R1150RT '02, R1200GSA '11
    Oct 2011
    Florida & Massachusetts
    Brian
    Just a quick check. What coding plug is installed in your electrical box? Coding plug is positioned, mid box called Relay 1 below. On your bike it should be Yellow and connect pins 30 and 87.
    Do you have any other add-ons, for instance a Powercommander, Techlusion or BoosterPlug?
    RB
    Cromwell CT
    Quote Originally Posted by DougRaymond View Post
    Hey I like this answer! I am going to try pulling it out a bit and see if I can get it to repeat the problem I had.
    Also thanks for the diagram on the fuse/relay box.
    Brian
    Mar 2007
    Ambler, PA
    .. Also thanks for the diagram on the fuse/relay box.
    Thanks to Roger 04 RT for that.
    Doug Raymond,
