Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: cam chain tensioners
  1. #16
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    I've done a few now and all the updated one piece plungers (no loose spring) will only fit into the 15mm head.
    This picture is courtesy of ADV riders - note the hex size difference
    Ufda happens..........
  2. #17
    Mar 2007
    Ambler, PA
    Don't wait
    There are those that believe that the old style tensioners contribute to the chain guides breaking and that is real bad news. Replace if you have the old style.
    The LHS cam chain is being improperly tensioned with original tensioner, it's just a question of how long one can get away with it.
    That said, OP can probably wait till 50k maintenance.
    My LHS tensioner failed at about 130k miles. The plastic chain guides had been worn through, then shattered, then the chain jumped off the sprocket and kinked.
    Some speculation on causes, perhaps real experts will comment:
    -the old LHS tensioner (17mm bolt head, 1998-2006?) failed due to clogged oil port, causing the piston to stick instead of pushing down on the upper chain guide.
    -the RHS tensioner never (?) fails, because its piston pushes UP and somehow the oil drains from it without problem.
    -it's possible that frequent oil changes help prolong the original LHS tensioner, which depends on very clean oil.
    Doug Raymond,
    R1150RT '02, R1200GSA '11
  3. #18
    Feb 2008
    Quote Originally Posted by DougRaymond View Post
    Thank you for the explanation.
    I have read that the Left one drains down on a hot shut off. When the bike is started the next time there is little tension until the oil pressure builds.
    The Right one does not drain down because it is inverted under the cylinder.
  4. #19
    Mar 2007
    Ambler, PA
    ..I have read that the Left one drains down on a hot shut off. When the bike is started the next time there is little tension until the oil pressure builds.
    That makes much more sense, thanks.
    Doug Raymond,
  5. #20
    Yes it does. Look at those photos of the old and new styles.
    On the left side the old style "cylinder" or housing screws down from the top and the piston sticks up from the bottom, giving gravity the perfect opportunity to suck the oil out of the upside-down cylinder.
    Notice that the new style has an entire tensioner similar to those on the F650 and F800 which sticks up inside the new style housing. And not that the tensioner cylinder goes in down and the piston sticks up ito the housing - keeping the oil inside the tensioner, inside the housing screwed down from the top.
