Results 1 to 4 of 4
Thread: 1994 K75S ABS I Rear Brake Fluid Reservoir
    I am in the process in replacing my old brake lines. Ordered the kit from Spiegler.
    This would be good time to replace the ABS rear brake reservoir hose. Is this hose a BMW part (can't locate it) to just a automotive store item?
    Expect The Unexpected
    Quote Originally Posted by Slipster View Post
    The BMW part number is 34321457880. About $7.00
    It isn't particularly special. It holds gravity pressure only from the reservoir down to the master cylinder. But it has to be a "rubber" material that is impervious to DOT 4 brake fluid. Not all hoses are. So unless there is a particular reason not to just get one from a dealer - they will need to order it - that is what I would do.
    Thank you Mr. Glaves
    Available from Max's:
    34 32 1 457 880, Hose, for $5.00 ea.
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
