Results 1 to 15 of 22
Thread: R1150RT (2004) Headlights Out
    Bill Lumberg 175781's Avatar
    Dec 2011
    This morning when I set out for my commute, at the bottom of the driveway, I noticed that I had no headlight. No low beam, no high beam. Euro switch was in the on position. Actuating high/low and euro switch had no effect. To be honest, I have noticed a couple of times on startup that I had a weak highbeam instrument light on, on the instrument display, even though I was in lowbeam mode. Switching the beam switch back and forth once or twice resulted in the dim light going away, and then things functioned normally. This may or may not have the slightest thing to do with having no lights this morning. All other startup functions, indicators, and lights function normally. Your thoughts appreciated.
    R75/6, 2004 R1150RTA.
    RD'nNH&AZ rdhudson's Avatar
    Apr 2012
    Switch
    Sounds like you need to research the functioning of that Euro switch. Do a wire wiggle test on the wires coming out of it. Do you have the origional switch? Plugging it in would tell you if it's the switch. Could be the wire connectors of course and that you can service with some contact cleaner and a plug-unplug cycle or two.
    Massachusetts
    Quote Originally Posted by 175781 View Post
    When the common ground connection fails just below the lamps, neither high or low beam works, but the Hi Beam indicator comes on. The ground failure is not unusual.
    RB
    Dec 2011
    Parking lamp works. No headlight. High beam indicator stays lit.
    Quote Originally Posted by roger 04 rt View Post
    RB
    Dec 2011
    Switch is the original switch. Not sounding like that's it though. Will keep the contact /plug-unplug in mind.
    Quote Originally Posted by rdhudson View Post
    Massachusetts
    Sounds like it's the common ground wire, up front, under the cowling, near the sockets for the bulbs.
    Mar 2007
    Ambler, PA
    Is your bike European-built, with original European headlight switch?
    That configuration was as best I could figure out for R1100 (maybe not your R1150RT '04):
    Headlight Switch Position:
    1. Off
    2. Instrument lights
    3. Instrument lights and hi/lo beam per other switch
    Hi/Lo Rocker Switch:
    Center: lo beam, only if other switch is full on
    High: (momentary) Flash high beam, regardless of other switch position
    Low: (detented): hi beam only, and only if headlight switch is full on
    I would be glad to hear any comment or correction from European R bike owners.
    USA-built R1150RT in 2004 and later have fuses for high and low beam (F8 and F9), you've probably checked that.
    Doug Raymond
    R1150RT '02
    Ambler, PA
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    Check your battery!
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Registered User jcabiles's Avatar
    Nov 2013
    Vienna, VA
    Same problem on my 04 RT-P
    Bad grounding wire as others have said. George at BUA added another ground wire and that solved the problem.
    Camas Valley Oregon
    Similar problem with my 04RT. Headlight assy replaced not once but three times under warranty in first year of ownership (bought new in 04). The ground for the h/l system consisted of some flaky copper strips that burned out and made replacement ot the 400.00 light necessary.
    Dealer blamed my Kisan modulator and after I removed it there were no further problems.
    Nov 2013
    Vienna, VA
    also ...
    Quote Originally Posted by jcabiles View Post
    ... and there were a couple other related issues that were fixed at the same time as the bad ground wire: high beam bulb holder was worn, Kisan headlight modulator is damaged.
    motorcycle cowboy Tennessean's Avatar
    Oct 2005
    East Tennessee
    Quote Originally Posted by mpmarty View Post
    Mine said it was the clear headlight protector that caused mine to fail.
    2013 Goldwing
    Quote Originally Posted by DougRaymond View Post
    1. Off
    USA and euro bikes have same wiring, they just left off the headlight switch on USA versions. You can easily buy and plug one in to your USA model.
    Position 2 of headlight switch is "parking lights," which includes taillight and the little bulb in the headlight and, yes the instruments. Position 3 is all of above plus power to the beam selector. Power for the flash portion of the selector is entirely separate, as you can flash with headlight off. On some if not all German cars, you can "flash" even with ignition off, but motorcycles are too vulnerable to tampering for this.
    And of course, all Oilheads are German-built, some just built there to USA requirements.
    Mar 2007
    Ambler, PA
    I've been trying for a long time to draw this "same wiring" in an understandable way. My current diagrams attempt to show the alternative European switch but it is not complete. Any source for a good schematic would be appreciated. i couldn't get much from Haynes or Clymer or even BMW drawings.
    I think you're right. Again, it's very hard to draw this circuit especially since 2002 oilheads and later have the taillight controlled by the ABS module.
    Yes, I meant "built-for-USA", when I wrote "USA-built".
    Thanks for info.
    Doug Raymond
    R1150RT '02
    Ambler, PA
    Nov 2013
    Vienna, VA
    Headlight Modulator Schematic
    Does the attached help any.Headlight Modulator.pdf
