Results 1 to 5 of 5
Thread: Aerostich Darien pad exchange
    Lost again Texpaul's Avatar
    Oct 2006
    San Antonio, Tx
    If anyone here has done the TF5 pads, or aftermarket pad, exchange on the Aerostich Darien jacket and/or pants I would like to hear your feedback. Both the good and bad. Thanks in advance
    Paul Mulhern
    MOA# 56330
    "The fact that the jellyfish has survived for 650 million years despite not having brains gives hope to many people!"
    Oct 2006
    San Antonio, Tx
    Since no one replied to my question I went ahead and ordered the TF5 elbow/knee pads (#1104) and the Transit pad adapter pockets (#1107) to try the conversion out. Here's what I found out.
    The velcro on the pockets did not align correctly with the velcro in the pants. This made correct placement of the pockets almost impossible. In addition the packets were larger than the TF5 pads allowing the pad to move around considerably within the pocket. This meant that even if you could get the pocket in the correct location the movement of the pad within the pocket defeated your placement efforts.
    In conclusion I would have to recommend that you do not waste your time and money on these Aerostich products as they do not function as advertised. After using Aerostich products for over 20 years I have to say that the company is not what it used to be and this will be the last Aerostich suit that I will own.
    Paul Mulhern
    MOA# 56330
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Have you tried bitching to Aerostich instead of here? If so what was their reply?
    I have the transit hip pads in my AD1 pants. Much better than the older/larger pads with respect to comfort. The velcro is not an issue as the smaller hip pads mount using the waist velcro only.
    I have the transit back-pad sleeve for my Darien jacket. Fit is perfect. However, instead of purchasing the (expensive) pad from Aerostich I purchased a SAS-Tec backpad (same thing) from a third party for about 1/2 the cost. FYI: the SAS-TEC size SC-1/12 is the perfect fit for the Aerostich Medium sleeve that fit my size 40 Darien jacket.
    Registered User tbowman2's Avatar
    Jun 2012
    Findlay, OH
    Darien jacket pads
    I purchased the TF5 elbow pads and sleeves for my Darien jacket and am very pleased. The TF5 pads are much less bulky, therefore more comfortable. Haven't tried the shoulder pads yet.
    Tom
    Findlay, OH
    F650GS
    Wilmington, NC
    I've done quite a few pad upgrades to older gear of various brands.
    The usual issue is getting a good fit and that's most easily handled if the pad material you select is trimmable- at least that allows accurate downsizing.
    My general brand preference in pads these days is D3. Trimmable, vented, softer, flexible so preferred by me to SAStec which are hard, non-vented, not very flexible, etc. SAStec and D3 are both meet current certification levels but the SAStec are cheaper which is no doubt the reason OEMs use them sometimes.
    Maybe some day we'll see standardized pad sizes and nomenclature or at least interchangeability tables - there are a few of those available now.
