Results 1 to 11 of 11
Thread: Does the Nav speak through the bike"s speakers on GTL?
    My 14 GTL didn't come with a Garmin GPS manual. There wasn't one in the box and the shop installed the unit on the bike. I can't seem to be able to figure out how to get the GPS directions speech to come through the bike's speakers. Any suggestions?
    Other then that, I am quite used to Garmin GPS units and used to the Zumo 220 on my previous bike, so I mostly have it figured out. The BMW version of the 660 lacks a speaker (I guess) so I expected it to talk through the bike. Perhaps I have to have the radio on?
    I also know how to use the BaseCamp software and this new unit works just like the 220 but with much more storage space. That's nice. The handlebar controls are quite minimal frankly. For example, it appears I still have to touch the GPS screen to select my destination, or to add an intermediate destination like a gas station or restaurant.
    Any assistance is greatly appreciated.
    Aug 2013
    NB, Mass
    Does the nav show up in the menu selections?
    If it does, then the bike is connected. Don't think speech comes through without the radio on.
    The nav doesn't come with a manual anymore, I got the box and everything with it but no printed manual.. But you can find it here:
    http://www.teamgreenrealty.com/k1600/
    Mike
    13' K1600GTL
    Biker gunnert's Avatar
    May 2008
    Catlett, VA
    No, the GPS does not transmit through the speakers, only bluetooth to helmet.
    NoVA
    '12 K1600GT
    Registered User dancogan's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by gunnert View Post
    I don't believe this is correct. As a matter of fact, you can set the GPS volume independently of the radio volume ... if you can find the proper menu item. But as previously said, it only works through the speakers when the radio is on (in which case the digital speedo disappears). At least this is the case for my Nav IV. I haven't tried it with a Zumo 660 to see if that plays through the speakers.
    Dan
    Maryland
    My Nav V also works through the speakers when I have my headset turned off (radio on). It also "remembers" my preferences for muting the nav voice for each output mode (speakers or headset). The manual file is stored in memory on the device--you can get to it through the usb port (as an attached drive) when you connect it to your computer.
    May 2008
    Catlett, VA
    I stand corrected...now to figure out how to get mine to play through the speakers! I'll play around with the audio menu as suggested.
    NoVA
    '12 K1600GT
    Mar 2012
    New Orleans, LA, USA
    Nav V "My Bike" page compatibility with the K1600GTL?
    Toolman_57
    I am not getting any clear answers as to whether this feature works with the GTL as it does on the New RT and GS models for displaying all of the bike telemetry. What has your experience been in this regard?
    -Steve
    R1200RTw San Marino Blue - 2009 Gillera Fucco
    Here's what I have worked out so far with GPS audio
    First I do have the GPS speech working fine through the speakers. It works with each source fine. I had to adjust the ratio of the volumes to get it right. There is a screen for that. I had to make that adjustment only once. I select the AUX for source input when I only want to hear the GPS. That works because I have nothing attached to AUX. I do have an Apple Nano attached to the usb input however.
    I cannot find, and my dealer concluded, that the GTL and NavV does not have the bike data info page. I find that strange since the other bikes with a less permanent GPS attachment do. I would have expected the GTL to have the bike data going into the GPS. It seems not to.
    I have fairly well worked out the process to create very usable routes using Base Camp and transferring them to the GPS. One trick that made a big improvement for me was making sure Base Camp only uses road intersections for waypoints and no other point of interest like a building or business. Otherwise the GPS wants me to pull into parking lots along my route.
    At this point my only real disappointment is that I have not found a method to use real simple bluetooth headphones and I am very disappointed BMW didn't include a simple standard mini plug for wired headphones. At this point I am not at all interested in a cell phone interface or any form of microphone. I just want what can come from the speakers to go to my earbuds.
    Any suggestions on that is greatly appreciated.
    Dave
    Impulse FrankFlorio's Avatar
    Saratoga Springs, New York
    If you can afford the Schuberth helmet - it pairs rather well with the K1600 GTL system - both audio and Nav V is a pleasure to use! You can get your mobile phone to work also by paring the phone to the Nav system. Just be sure to follow the detailed instructions in the Audio users manual for the bike to get it right!
    Good luck!
    '14 K1600 GTLE
    '08 R1200RT
    '08 F800ST
    '05 R1200RT
    Apr 2014
    Lincoln County, NC
    Quote Originally Posted by FrankFlorio View Post
    Good luck!
    I use a Bilt helmet from Cycle Gear with integrated Bluetooth, and it works great for about 1/4 the price of a Schuberth and about 1/2 the helmet quality.
    Registered User billblecher's Avatar
    Jun 2014
    Little Rock, Arkansas
    So what Blue tooth headsets work with BMW?
    I have a Uclear HBC 200 BT headset that would not pair to the 14RT. Paired with the Motorad V GPS just fine but dont want to listen to that B...h! get enough of that at home ! LOL. Needless to say I was not a happy camper when I figured out that it would not pair to the Bike. I really like that headset, Worked very well with my Garmin 665. My question is this what helmet and communication set ups WILL work with BMW? I dont want to hunt and peck through a bunch of headsets and spend a butt load of money to find what works and what doesn't.
    I would like to have my phone paired to the GPS, the bike and the GPS paired to a BT headset that will allow intercom, phone calls and listen to the radios. and switch accordingly. I have been told that BMW communicators and Schuberth C3 Pro helmets work. That is almost a 1200.00 bill when that is said and done. Would like something less expensive? Any suggestions? I am open to those.
    My 14 RT is going back and I am in the process of getting the K1600GTL. But I want to be able to listen to all that stuff in my helmet, not blasting through the speakers at 70+ mph.
    Bill
    05 R1200RT
    14 R1200RT Returned
    14 K1600 GTL in process
    I've been around the world, seen two county fairs and a goat ropin'........ BUT I AIN'T NEVER SEEN NUTHIN' LIKE THIS!
