Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 46 to 60 of 61
Thread: Fuel pump recall??
  1. #46
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by Dann View Post
    Not waiting for parts.
    Good deal
    Lee
    2016 R1200RS
    MOA # 30878
  2. #47
    May 2003
    SW Iowa
    Did you get a new fuel pump?
    Lee
    2016 R1200RS
    MOA # 30878
  3. #48
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    No. Mine was considered "within specs".
    They put the reinforcement ring.
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    R1200RT 2007 - IBA # 56396
  4. #49
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    I got letters for both of our RTs (2007,2008) last week.The last time I had the tupperware off on mine (2008) before I put it away for the winter I saw no indication of any issue but will schedule this in along with new tires this spring. I have not checked my wife's (2007) recently but am getting the brake fluid service completed along with new tires this spring so will address then.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
  5. #50
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    How hard is it to check this out myself. Is there a way to see it without total disassembly? I have an 2008 GSA.
    John Simonds
    2008 R 1200 GSA
    1975 Norton Commando 850 Roadster Mk 3
    If it ain"t broke... fix it till it is.
  6. #51
    Jan 2011
    kentucky
    fuel pump recall
    is than a sight you can put your vin number in and see if my bike is in the recall,
  7. #52
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by junkjohn View Post
    On my RT, all I had to do was to remove my left side panel (4 screws)
    I don't know with the GSA, but it should not be that complicated.
    Daniel
  8. #53
    Sep 2006
    The left badged cover comes off to expose the pump assy, the connector and the flange are visible. On the GSA , there is another assy and a fitting on the right side as well, I am assuming they will look at both on the GSA's.
    Steve Henson
  9. #54
    Feb 2010
    Cape Cod, MA
    Thanks for that, I am hoping to see for myself what this problem looks like.
    John Simonds
    2008 R 1200 GSA
  10. #55
    The NHSTA site shows my '08 r1200r being in the VIN range of the recall.
    I am not the original owner, so I contacted BMWNA and gave them my contact information.
    As of today, I have not gotten any correspondence.
    Anyone else?
  11. #56
    Quote Originally Posted by hlebowi2 View Post
    Anyone else?
    Called local BMW dealer and they ran my VIN #. Said it was on recall list and I have an appointment for a week from today. Also ordered metal quick disconnects from BeemerBoneyard and the dealer said they will install them when they do the recall.
  12. #57
    BTW, I never received any notification from BMWNA.
  13. #58
    atlanta
    Wow! Shocking.
    Marty Hill
    12 GS black/7 GS white
    ride till you can't
  14. #59
    The Blue Max 31310's Avatar
    Apr 2008
    Calgary Alberta
    leak '07RT
    Just replaced the fuel pump controller, used Haynes manual to troubleshoot for pump failure (it was good), filter etc, used info on this forum re the fpc, it had died. Bike started & ran great, then filled up and gas leaking down left side. Pulled off left panel, re tightened the metal retaining ring, leak slowed dramatically but its weeping from the tab on white collar fitting the fuel pump assy sits down in. Parts fiche lists this as a supporting ring 161 411 82 903. Anyone have same experience? P.S. Po'd 'cause can't ride & it's spring time.
    2007 R1200RT
  15. #60
    Apr 2008
    Calgary Alberta
    Checked with dealer here, said sounds like the flange is cracked & is covered under the recall; just have to wait three weeks to get in for check up and repairs. Better than being told, 'we've never heard of that before...'
    2007 R1200RT
