Results 1 to 9 of 9
Thread: Sidecar shock set up
    Registered User sit's Avatar
    Mar 2006
    Oregon
    Have asked on another forum, but so far there does not seem to be a concise answer. Was wondering if there is a general rule when setting up the shocks on a sidecar rig. Not as much interesting in what one person does because that is for that particular person, weight, rig etc. Am trying to determine if there is a general starting point for the three shock location, softer on front but sidecar and rear the same setting, or rear stiffer than front but sidecar softer than the front or what? On my Ural I was running all of the shocks in the same setting, but felt like the front was really stiff, that it had no recoil because I had it tightened up too much so I softened the front a bit and it seems like it rides and steers better now that the front can absorb the bumps more. I know each rig is different, that depending on the bike and sidecar there are different numbers of shocks to even adjust etc. Just looking to see if there is a generic starting point.
    2005 K1200LT-Ocean Blue
    2013 Ural Patrol - White
    2007 R1200GS-Granite Gray-Sold
    2004 R1150R-Titan Silver-Sold
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    You'd get some fantastic advice on the Hack forum on ADVRider.com, as they have a more active sidecar community over there.
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Tulliver
    Mar 2006
    Oregon
    I try over there too, thanks. Forgot all about them. I have a message on Soviet Steeds too, but no luck so far.
    Apr 2008
    SW Ohio
    I have never seen a consensus. One dealer said he sets them full soft, then the owner can stiffen them up as he see's fit.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Sep 2004
    Arlington, TX
    Springs?
    Are you referring to spring set up? During the /2 era, BMW offered different springs, front and rear, for sidecar use. They were a heavier guage wire, and stiffer.
    Boxerbruce
    Mar 2006
    Oregon
    I actually have Ural, was just trying to see if there is generic staring point out there, something like the front should softer than the rear and the sidecar should be softer than the front or some formula to start at so you can then fine tune it for your bike, weight, riding style etc. Seems like the answer is much like oil answers, all over the board, but no generic generally accepted starting point.
    Apr 2008
    SW Ohio
    with my Ural, I leave the sidecar soft since it is usually empty, the rear at full stiff and the front in the middle. Played around with different settings and these seem to work for me, 220lb usually solo.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Registered User vetsurginc's Avatar
    Apr 2005
    Parkland, FL
    Quote Originally Posted by sit View Post
    My Ural dealer (Gene at Holopaw, FL) advised to keep all the shocks on the Ural at the same setting - your choice as to what that setting is. I've got 22,000 km on my 2011 GearUp with the shocks at the softest position. Only bottomed out once (on the front) on a rock ledge 4" high (too much speed). No damage, just a good jolt. I use a Harley solo police seat instead of the original, which also is a significant part of the suspension
    I did spend time with them on the middle setting. But you would need a LOT of weight to make the suspension move (just me and the dog, so went back to the bottom). Still have original shocks.
    I think the answer will depend on the spring rate for the s/c. On my last rig I had the preload set to highest position with a 70/150 rate. On my current rig I changed to a 250/300 but have the preload in the lowest position.
    Bill D
