Results 1 to 11 of 11
Thread: Garmen 660 and map of Europe?
    St Paul
    Has anyone used a GPS in Europe? I am thinking about taking a 3 month trip in '15. Seening places that I couldn't go when I was in the Mil in the '80's. From the Nordcape to the Toe and everyplace between.
    I recently returned from Europe. I took my Nav iV and prior to leaving I purchased the Europe maps. What I did learn (after I realized the maps never loaded) was that i needed a memory card to store the maps on as they did not fit onto the actual memory of the Nav iV. It was simple though and with Map Source I transferred only what I needed. The device now shows that the Europe maps are there.
    There are base maps in the unit already but they lack the detail and accuracy of course and Poi too.
    Apr 2006
    Yes, you will have to purchase the Euro maps. Once that is done, operation is pretty much the same as in the US. Just do not let the GPS pick the route, the small roads are the reason to go to Europe, and if navigating point to point, it will probably miss them.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    St Paul
    Small Roads
    Quote Originally Posted by pffog View Post
    Is there a function in the 660 to limit turnpikes and autobahns? I am going over to see places that I couldn't go in the early 80's. I was in the military then.
    Apr 2006
    Quote Originally Posted by bernie View Post
    I am running an old school 478 (big brother of the 276C family) and I can chose which type of roads I want to be routed or avoid. But that is not really what I was talking about, even in the US, I rarely just let the GPS plan my route.
    If you want to really see the out of the way places, spend some $$ and get some of the detailed European regional maps. I prefer the Michelin, 1: 200,000 or 1:300,000 scale ( http://travel.michelin.co.uk/regional-maps-138-c.asp ) others are Freytag & Berndt, and Touring club Italiano. Almost all brands highlight scenic roads, which are a good bet. Many very small roads in the Alps are paved, so don't be afraid to wander. Google Maps street view was very good and would let you check out roads to see if paved when you are planning, but they have had to remove their Swiss, and German views for Government reasons.
    My MO is to spend some time on with the paper maps, Google and Garmin mapsource, and rather than routes, just put markers on the roads I want to explore, Then when I get to an that area, check the maps and plot rough routes into the GPS so I can get there without too much drama, and I am not afraid to toss out all plans, if a roads leads me elsewhere.
    Almost all the main routes in the Alps are paralleled by small roads, and most are paved, narrow twisty beyond imagination, and FUN, if that is what you like.
    Canada and the Alps
    Exactly.
    I always advise quality paper maps with a scale of 1:200 000 or better to pick your routes.
    Use the GPS to get you somewhere when you need to get there efficiently.
    To the OP, I use a Garmin GPSMAP 60 Cx with Euro maps. I know it has a small screen and does not talk, but my primary use is logging my tour and marking photo locations (camera time synched to the GPS). Plus that unit will run all day on a set of rechargeable AA batteries.
    Eastern KY
    With the popularity of smart phones Garmins,etc. are for sale on the cheap by the 1,000's on ebay & CL, these days. I bought a lifetime maps Nuvi with all the acc.,hardly used and that model takes Euro maps card too for under $40. Not waterproof model but easily carried in a MC jacket pocket/tankbag or street pants when your off the MC. My Zumo is bulky and not going with me to Europe for a fly & drive.
    "If I had my life to live over, I'd dare to make more mistakes next time...I'd relax,I'd limber up... I would take fewer things seriously...take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges at age 85.
    Registered User jcabiles's Avatar
    Nov 2013
    Vienna, VA
    Local Knowledge - Central Germany
    I spent two tours (8 years) in Germany with the US Army, in the vicinity of Frankfurt and have travelled to other parts. I would be glad to give you some suggested POIs and things to do while in Germany.
    Gute Fahrt!!
    Quote Originally Posted by ppaintguy View Post
    +1 The same thing happened to me (with a 660). Once I got a memory card, downloading the maps was possible and everything worked like a charm.
    Thor Anderson
    Marin County
    K1200GT
    R100GS
    AZ
    I use open street maps when I am in Europe. http://garmin.openstreetmap.nl/
    You can choose any combination of areas you want and compile a Garmin compatible and routable map. I load this on an SD card and plug it into my Garmin for a second map set. I used it extensively in Germany with no issues. FREE.
    MOA #107139
    RA #28511
    YB #2005
    Registered User cameleer's Avatar
    Jun 2014
    Dubai, UAE and - for now - Munich, Germany.
    Not really, you can only choose between Most Direct Route or Fastest Route, but you can plan your rout on Google Maps and then transfer it to your Zumo, or even easier, plan your route directly on the device with the help of a really good map, like a Michelin.
    Cheers
