Results 1 to 10 of 10
Thread: Rubber protectors in fuel tank? K75
    MontanaMark kmellzey's Avatar
    Nov 2010
    Helena, MT
    I was changing my fuel filter in the k75s and came across these protectors/bumpers in the bottom of the tank. The short one is about 3" long and the long is about 4". Each has a groove down the center, like they press over some metal "thing" inside the tank.
    My thoughts are that they cover some of the sharp support structures in the tank to protect hoses/wires from getting cut by vibrations. However, wouldn't the protectors themselves vibrate off?
    Does anyone have ideas as to where they go?
    Thanks,
    Mark
    Last edited by deilenberger; 02-05-2014 at 03:27 PM. Reason: Added model to thread title
    Spring Lake NJ, USA
    Mark,
    Please review: http://forums.bmwmoa.org/showthread.php?46057 - I'll add that info (at least the model) to the thread title in the hope that someone with some K75 (and likely K100) specific knowledge may be able to help. Please put that info into future thread titles..
    Thanks for your cooperation,
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mark,
    I don't belive they should be in the tank. They are not shown (in the tank) on the parts fiche. I do not remember ever seeing any in any tanks before.
    The ARE two similar pieces on the outside bottom seams.
    Later this afternoon when I get back to the shop, I'll have a look at the several bikes and loose tanks to see if something stands out.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2012
    Los Angeles, CA
    Neither of mine (both 1987) had those, though I suppose I can't say they never had them.
    All the in-tank wires and hoses were routed such that there was no worry about vibration against any sharp surface, as I recall. I never had a concern about that.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Mar 2008
    Belton Tx
    I thought they looked familiar, so I checked my 91 K75RT tank. They go on ribs on the left side of the pump bracket. Short on rear and long on front.
    Ron
    91 K75RT ABS
    Nov 2010
    Helena, MT
    Thanks all
    Thanks for all the input. Obviously, if I had them on the bench to take a picture, they aren't in the tank anymore.
    roncooper - Thanks - I checked the fiche and didn't see anything, then checked the Haynes manual - nada. Next time I go in, I'll check the fuel pump bracket.
    JamesinCA - I'm not too worried about wires or hoses either.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The purpose of the rubber protectors appears to be to keep the shelf that the fuel pump is mounted in from vibrating against the side of the tank. The shelf is welded to the hump in the center of the bottom of the tank but is not welded to the side of the tank. The bottom (with the shelf attached) is joined to the top with welds along the bottom seam.
    I doubt that you could replace them on an assembled tank. Probably why they are not listed in the fiche. I'll try to get a look at one of my spare tanks to see if you could access them.
    Mine, Hers, Spare
    Nov 2010
    Helena, MT
    Lee - sounds like an artifact of the manufacturing process. Thanks for taking a look.
    Mark
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mark,
    Here's where they go. If the ones you found in the tank are extras, no problem. Throw them away. But if they are the ones from your tank, you MIGHT be able to slide them down from the top. Make sure the slit goes over the edge of the sheet metal.
    Mine, Hers, Spare
    Nov 2010
    Helena, MT
    Lee,
    Thanks for the picture. I'll put them back in a) if I hear rattling where I shouldn't or b) next filter change.
    Thanks,
    Mark
