Results 1 to 10 of 10
Thread: Centerstand vs. Sidestand
    Registered User LDB's Avatar
    May 2013
    Houston
    I've got a 1977 R100/7 I hope to get back on the road later this year. I'm curious if it makes any difference in oiling the bike if it's on the sidestand vs. the centerstand as in initial startup after sitting for a period of time.
    CCC, NRA, OOIDA Life Member
    BMWMOA Member 15945
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    I really DO NOT understand what OILING is........But for starting an engine after it has been sitting for a long time without running, for me I would have it on it's center stand. If for no other reason so that the float bowls are hopefully "even" on both carbs and cab possibly NOT overflow and cause problems.
    Oiling???? Like putting oil in????.......Like squirting oil on the various moving parts?........If you are checking the oil, definately on the centerstand...............Good luck and God bless...........Dennis
    May 2013
    Houston
    Even and proper oil distribution through the engine immediately after hitting the starter button. One might think the oil would run toward the downhill side when on the sidestand. I hadn't thought about the carbs but I can see that point also.
    BMWMOA Member 15945
    Quote Originally Posted by LDB View Post
    This is the "wisdom" of the "old guys" and this idea has been around for 30 or 40 years. It has been accepted as true (excessive oiling of left cylinder upon startup after bike was parked on side stand) by most, but there are a few unbelievers.
    This was hashed out pretty thoroughly on a previous thread about 2 months ago.
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
    Administrator 20774's Avatar
    I would think that on the sidestand or centerstand would make no difference in getting oil to the engine immediately. Sure, the oil in the sump will move to one side, but the reality is that the oil pickup is always submerged in oil, provided you are maintaining the proper level of oil per the dipstick. Thus upon first flick of the start button, oil is being drawn in and pumped through the bike.
    Just the same, I would pull the plugs out and crank the engine until the oil pressure light goes out. That will get oil to the various parts with little / no load.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Quote Originally Posted by cseltz View Post
    Totally Agree!
    Just to be clear, pull the plugs and ground them to the cylinders. Or another possibility is to drop the float bowls.
    In my opinion, pulling the plugs is best. It removes compression which makes it easier on the battery and reduces load on the "dry" parts.
    Good point...there are several ways to accomplish this. Pluses and minuses go with any approach. Personally, I don't like pulling plugs unless necessary. Chances for screwing up the threads exists...having the plug not well grounded. Stuff can happen no matter what we do.
