Results 1 to 6 of 6
Thread: 78 r80/7 breather tube
    Aug 2008
    Cape Cod Ma.
    Hi does any one have a source for the crank case breather tube? the ones I can find are to large diameter. Tried Max so far.
    Brian
    86 k100rt, 78 r80/7
    Albuquerque, NM
    So are you saying this part is no longer available from BMW?
    Kent Christensen
    21482
    Dec 2012
    Unless the part is no longer available, I don't see why it would be "too big."
    I would also try RePsycle near Columbus, OH - perhaps they have a used one if a new one isn't available.
    Also that person from Greensboro, NC who is constantly selling airhead parts in the Flea Market section here.
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
    Aug 2008
    Cape Cod Ma.
    I did get one from max, the overall shape was right, but the outside diameter was to big to go into the air box, like no way it was going in there. I was able to seal my old one enough to reuse it. I will not be riding this bike cross country.
    Brian
    86 k100rt, 78 r80/7
    Administrator 20774's Avatar
    The fit of the tube into the right-hand clamshell is very tight. The last time I had it out I struggled mightly to get it back in the outlet hole. I used silicone lubricant and carefully used a needle nose pliers to coax it into place.
    Aug 2008
    Cape Cod Ma.
    the hole in the air box is 20mm the tube was 23+ as I said, no way, used armor-all, no way
    Brian
    86 k100rt, 78 r80/7
