Page 16 of 17 FirstFirst ... 6 14 15 16 17 LastLast
Results 226 to 240 of 253
Thread: tranny input shaft
  1. #226
    Registered User Blacque Jacque Shellacque's Avatar
    Nov 2005
    Pickering, Ontario
    There is a relief in the metal to allow for the tang just to the left of the left threaded hole
    There is thin line visible where it was pressed.
    A .025" feeler gauge fits in with the bolt tightened up, the tang measures @ .027" so that is an .002" interference.
    IMO that holds the spring tangs firmly in place.
    This is great information, thanks. Interestingly, I do not measure a gap in the relief area of .025. The interference make sense though.
  2. #227
    Instigator cele0001's Avatar
    Feb 2014
    Jacksonville FL
    By the way, what are the tangs for?
    I want to be unique, just like everybody else.
  3. #228
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Quote Originally Posted by cele0001 View Post
    They hold the fwd friction plate in position
    Ufda happens..........
  4. #229
    Can anyone offer opinion as to the cause of the black scoring on my R1150RT housing cover? This bike did have input shaft and clutch hub failure. Could this be further evidence of misalignment? I'm assuming I should replace this part also. What's another $186 at this point?
    04 R1150RT
  5. #230
    Oct 2011
    Florida & Massachusetts
    What's the dark spot at the 12 o'clock position?
  6. #231
    Quote Originally Posted by roger 04 rt View Post
    That's my concern...any thoughts Roger?
    04 R1150RT
  7. #232
    nothing remarkable, in my opinion, on the corresponding wearing surfaces of the clutch plate
    04 R1150RT
  8. #233
    Curmudgeon nrpetersen's Avatar
    Sep 2004
    minnetonka mn
    Aside from being very slightly conical, is it warped? depression in the black area? Is the flywheel warped? (I understand it is not.) How about those three flexplates around the perimeter? Any cracks in them?
    FWIW some years ago I saw a pix of similarily burned flywheel face on an oilhead that I attributed to friction heat from the clutch disk being dragged around the flywheel? Maybe not?
    Retired w 2005 K1200LT, 2000 R1100RT, & 1975 R90/6
  9. #234
    Quote Originally Posted by nrpetersen View Post
    Neil, I can't tell if it's warped. There is definitely a pattern of wear from outside to in (see photos) There also does appear to be a slight depression in the black area and also the metal feels rough. I do not see any cracks in the casting of housing plate or anywhere in the pressure plate. Clutch Housing 3.jpghousing cover2.jpg
    My attempt to determine if the flywheel is warped was inconclusive with the use of a straightedge.
    04 R1150RT
  10. #235
    Feb 2008
    Quote Originally Posted by mhuf View Post
    Those marks are from heat - sliding the clutch
  11. #236
    Is this wear(worn circle center frame) on the outside of the clutch housing cover normal?
    04 R1150RT
  12. #237
    Thanks GSAddict. Sliding meaning either incomplete engagement or disengagement of the clutch for extended periods?
    Is the outside to interior wear pattern normal? Would you recommend replacing this cover?
    04 R1150RT
  13. #238
    Feb 2008
    Every one I have taken apart looked like that. BMW recommends that the whole assembly gets replaced so the new clutch plate will wear properly.
    On all the client bikes I have done that because of comeback potential. (client ultimately made the decision)
    On my own machine (256,000km) I ignored it and just replaced the disc. No issues whatsoever over 3 discs.
    Disc 1 @ 75,000km - to fix trans oil seal leak (replaced stock input shaft as well)
    Disc 2 @ 152,000km - replace stock input shaft with custom longer unit
    Disc 3 presently running
    I am still running all the other original clutch parts. (including the slave cylinder)
    All I did to the friction surfaces was roughen the with an orbital sander & 100 grit emery sheet.
  14. #239
    Feb 2008
    Yes that is done for balancing purposes
  15. #240
    Feb 2008
    Basically starting on a hill loaded up and sliding the clutch too long to get going.
