Results 1 to 12 of 12
Thread: 78 r 80/7 sub frame
    Aug 2008
    Cape Cod Ma.
    78 r 80/7 sub frame
    Hi, I was wondering what attaches to the lower holes on the tabs where the sub frame bolts to the main frame, the upper part of the sub frame?
    Also the upper sub frame bolts that are on the bike are regular bolts, so to get the battery in and out, I have to pull the bolts out to slide the battery by, is this correct?
    the bike is 78 r80/7
    Brian
    Brian
    86 k100rt, 78 r80/7
    Northern Front Range, CO
    Battery should be able to slide out by moving it forward into the area occupied by the air cleaner assembly, once all the air cleaner stuff (intake tubes, 2 sided clamshell and filter) is removed.
    Lift handle on left side uses up 2 holes, but not sure if that was the missing part/holes you were asking about.
    Ride Safe, Ride Lots
    Administrator 20774's Avatar
    Brian -
    I'm not sure about the lower bolts, but as for the upper bolts, I remember it well removing the regular sized lead-acid battery. I find I have to remove one of the upper bolts and maybe help spread the frame a skosh. Also, it helps a lot to loosen the undertray bolts that hold the rubber mounts in place as well as the two bolts on the upper sides. This allows for the whole tray to be tilted back and makes sliding the battery out much easier. Yes, getting one of the newer fangled batteries eliminates all this, but I have some comfort in using the stock sized lead-acid battery.
    Hmmmm>
    How big is a "skosh"?
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
    Mar 2010
    Vancouver, B.C. Canada
    Brian -
    Sounds like the same deal on my '82 RS. I've had the Panasonic battery in there for five years now. I used foam spacers so the width is OK in the battery box. Nice grab hole design in the top makes it easy to pull out. The stock OEM BMW battery (still dry and waiting for the Panasonic to croak) requires the removal of the two top rear frame bolts, loosening of the battery box mount bolts so it tilts back all the way to the fender and even then it's a tight squeeze to get in there. It does fit the battery box perfectly.
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    It's pretty much equal to a couple, three, or four leeetle bits.....God bless......Dennis
    Hmmmm>
    That's a technical term! It might mean something different to different people. I try a small skosh, and if that's not enough, I usually go for the bigger variety!
    Merriam-Webster definition of a skosh.
    Jun 2007
    Edmonton AB Canada
    Battery removal
    I have had good luck sliding the battery forward into the void created by removing the air filter clamshell on my older airheads.I seem to find that there is always one battery box rubber standoff that proves recalcitrant!
    Russ
    '76 R90/6 '78 R80/7 '78 R100RS
    Mar 2010
    Quote Originally Posted by beemerus View Post
    Russ
    I'll have to give that a try when the Panasonic dies. It's been in there five years and it won't be long now judging from the slower cranking after sitting a few days.
    I always assumed those extra holes were for a sidecar.
    Aug 2008
    Cape Cod Ma.
    Update on frame bolts. I had an 86 r80 a few years back, and the upper bolts on the sub frame were counter sunk, I got the newer style bolts and the one ream that I own was had the right size point to set them flush, so maybe I will get the battery in and out.
    Brian
    86 k100rt, 78 r80/7
    Quote Originally Posted by 44817 View Post
    As lchris will point out, BMWs after 1969 are not designed to handle a sidecar and the loads plus the front suspension is wrong...that's what the Earles fork was all about. People do it, but it's not really recommended.
