Results 1 to 4 of 4
Thread: Inconsistent Spark with timing light (92 GS)
    '92 R100GS '81 R100/t brittrunyon's Avatar
    Sep 2009
    Ojo Caliente, New Mexico
    When timing the engine I get a very sporadic light from the timing device.
    Same for R & L plug wire.
    The coil is new, as of 5 minutes ago.
    The connections are clean.
    The timing is right on. (on mark below "S")
    see video
    http://s1089.photobucket.com/user/br...10e10.mp4.html
    Which way should I look.
    1992 R100 GS, 2007 F 650 GS
    Big Bend Ride video at http://brittrunyon.com/
    More riding videos @ http://vimeo.com/user2721333/videos
    Administrator 20774's Avatar
    Model of timing light? Inductive pickup? Move the inductive pickup (I'm assuming that's the type) closer to the spark plug. What is your power source for the light? Try and use a separate power supply, like the battery in your car. Also, borrow a timing light from someone and rule that out as a problem.
    Sep 2009
    The timing device in question.......
    I used the bikes battery.
    I suppose I could bring the F650 over & use it's battery.
    Thanks 20774
    Online info says it's inductive "with metal clamp". What's the clamp do?
    http://www.tooltopia.com/equus-3551....FUMV7Aod838ARw
    The video mentions "patented Skip Circuitry Test" and the flashing light in the video almost seems to be what you're seeing. Could it be a feature that you need to disable?
