Results 1 to 15 of 17
Thread: F650GS Front wheel removal
    delaware
    Question F650GS Front wheel removal
    Forgive please
    My 2011 F650GS needs a front tire replaced with only 15,100 miles on it.
    I have the replacement tire.
    But am looking for someway to get the front wheel in the air.
    The bike has no center stand and I do not see where to "jack" the bike up except the engine.
    What have some of you done?
    Max
    Mansfield,MA
    The Globeriders DVD had some interesting ways of lifting either wheel of my F800GS. Other than that I've used a milk crate and some wood kinda rocking it on. Some have lifted it from the rafters of their garage and then slid some support under it. If you had some help around it should be no big deal, just make sure it stable as some rocking will occur when you do the work.
    HTH.
    Mod Squad
    2009 F800GS 1994 TW200
    Jul 2007
    THE BIG SKY
    Hydraulic floor jack or scissors jack. Bike in 1st gear. Wood between the jack and the engine. Tie the bike off on both sides for stability. The tie downs will be more effective if they are attached to a point horizontal to the point of attachment on the bike as opposed to down to the ground.
    Only 15k on the tire? That's pretty darn good.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    When we bought Voni's F800S it didn't have a centerstand. Before we left the dealership (Bentonville, AR) we had them order a centerstand. By the time we got home (Texas) the stand was here, ready to be bolted in place. Which is to say, if one is available I wouldn't own a bike absent a centerstand.
    Contemplate that hydraulic jack and tieing off the bike when you need to remove a wheel beside the road or in a motel parking lot. Such things do happen.
    Northern Front Range, CO
    you will use this more than once, guaranteed.
    http://www.harborfreight.com/1500-lb...ift-60536.html
    Ride Safe, Ride Lots
    172526
    Jul 2012
    Just ahead of a flat line
    An old car tire, chunk of styrofoam etc etc and blanket, lay the bike on its side against the tire so the front wheel is free. (my other bike is a KLR)
    delaware
    Nope
    That works fine on bikes with wide spaced frame rails, like a harley big twin.
    My F650gs has almost no frame. Everything under the front of the bike is engine.
    Thanks anyway.
    Max
    Jul 2007
    THE BIG SKY
    Everything will be easier from chain maintenance to tire repair and inspection with a center stand.
    Kevin Huddy
    172526
    Jul 2012
    yup they are the best way. All of our bikes have centre stands and it would be the first choice of an accesory .
    I am too poor to buy cheap stuff, I need it to last forever (tewster2)
    Quote Originally Posted by MAXSCYCLE View Post
    Thanks anyway.
    Max
    works great on my F8GS... but I have a heavy duty Adventure Spec skid plate mounted, which gives a large platform for lifting.
    ultimately, if you plan to keep the bike for any length of time, you're going to want to slap a c-stand onto it. too many basic maintenance tasks want at least one wheel off the ground, if not both.
    as has been advised, there are plenty of cheap a$$ solutions... but they remain cheap a$$ solutions.
    May 2012
    DeSoto MO
    Quote Originally Posted by garthw View Post
    I've seen this one before in a photo, but have always been a bit concerned about trying this sort of change out unless in an emergency situation. Do you have any links to a video that shows the process? Since the bike is on it's side for a bit of time, do you have any trouble starting it up due to oil draining into the spark plugs? Is there any tip over safety switches that will keep her from starting back up after being on its side for a long length of time?
    172526
    Jul 2012
    Quote Originally Posted by weschmann View Post
    Yes prob not anything you would want to make a habit of. My post was in reply to the fact that you may need to do something without the aid of a jack or alternative. Actually did this with my KLR using 2 tires and it was not really leaned over too badly before the front wheel was free to remove. It was in that position for at least an hour. Stood it up let it settle for a minute, and started right away.
    Jul 2007
    THE BIG SKY
    I've seen some KLR guys use a prop that they attach to the rear axle (I think). That along with the side stand allows for the bike to be easily tipped. It may only get the rear wheel off the ground, I cannot recall for sure. Been a long time since I saw one in action and my memory is fuzzy. Checkout a KLR forum and maybe you can find what I think I saw and maybe it will work on a F650GS. My wife rides a F650GS and I surely would not want to try to maintain it without the center stand. Good luck to you.
    Kevin Huddy
    Sep 2008
    Wilmington, NC
    I certainly agree with the center stand as necessity. On every bike I own and I won't even consider buying a bike that can't be fitted with one (eg like some current J brand models where the under engine exhaust makes fitting a center stand impossible. Only dirt racers and road racers can make a serious case for no center stand requirement).
    But there should be no reason for hesitating to jack on the motor if the load is spread on wood or hard rubber, etc. I've done this on many bikes without jacking on the frame.
    Put a hunk of 2X4 across it, a small jack under it and lift the front enough to get the wheel off.
    Most bikes I've done this to are reasonably stable on just the jack and rear wheel. Add weight to rear of bike if it helps (put a cinder block, bags of lead shot or whatever on the rear carrier if you need to). You can add an additional support in case the jack leaks down, tie offs if a bit unstable, etc but I've never found it necessary and don't do it. Raise it only the minimum needed amount, remove fender bits if necessary so you can get the wheel out while keeping it low, if needed. Don't do anything stupid to push it off. Note however that I don't own a F650 so have never done that specific model. But we do have 6 other BMWs including F twins plus an old Honda.
    Lanark County near Ottawa ON
    Sitting on the center stand the bike is quite close to balance fore and aft. As a consequence the load on whatever you put under the engine to keep the front end up is rather modest. I use a floor jack - not because of the weight but rather the convenience of raising up just enough and then lowering it back down again. If the wheel is going to be off the bike for an extended period I put something under the front forks to support the front and take the floor jack away until it's time to put the wheel back on.
    mike
