Results 16 to 30 of 41
Thread: alternator belt 2010 R1200RT
  1. #16
    Registered User dundee387's Avatar
    Feb 2007
    Meriden, CT.
    I'm looking to do this job for the first time on my 06RT. Do all the plugs have to be removed to make the job easier?
  2. #17
    BruceRT
    Feb 2012
    Northern Virginia, USA
    Quote Originally Posted by dundee387 View Post
    Just one plug per cylinder so you can turn the crankshaft through the rear wheel while the transmission is in 6th gear.
    Bruce
    2005 R1200RT (It's new to me!)
    If you are not continuously learning, you are slowly getting bored.
  3. #18
    Spring Lake NJ, USA
    Quote Originally Posted by bdimon View Post
    I found it MUCH easier to turn the engine over using the crankshaft nut in the center of the bottom pulley.. you're sorta right there, and it turns over easily with a plug/cylinder removed. No real worry about changing the torque setting on it.
  4. #19
    Feb 2007
    Meriden, CT.
    The plugs on the bottom of the head, or the sides?
    Please forgive my lack on knowledge here....
  5. #20
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Doesn't make any difference. You just want to create an outlet for air on the compression stroke. I found it easier to remove the main plug.
  6. #21
    Registered User BoxerHund's Avatar
    Nov 2013
    24K vs 6 years
    I've changed three at 24,000 miles (40K); two RTs and an R. All looked good, but I'll change the next one at 24K as well. Now I travel with the used ones as back-up. It's not much extra work once you have the fairing off to do other routine maintenance such as the throttle body synch.
    I have a 2007 R1200R with about 12K miles on the clock. So miles-wise the alternator belt should be fine but my Haynes manual specifies a belt service interval of 24K miles or 6 years, the latter of which has just past. I suppose I should change it just in case? Are there non-visible signs of deterioration in these things? That is, if I examine it and find no obvious cracking etc, could I still be in trouble?
    Thanks,
    BH
  7. #22
    Mar 2008
    Camas Valley Oregon
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
  8. #23
    Jul 2007
    THE BIG SKY
    Quote Originally Posted by BoxerHund View Post
    Thanks,
    BH
    They seem to last much longer than the maintenance schedule would imply but I'd change it , or at the least buy a new one and carry it with you.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  9. #24
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    The point I made in my earlier post got lost in the translation it seems. When these belts fail - if they do - there is a reasonable risk that the failure will damage or destroy the hall sensor(s) or wiring tucked behind the pulley.
    So, while it is not a bad idea to carry a spare belt, the better approach is to change the belt so as to avoid the failure which may damage the HES and leave you disabled beside the road, lacking a $300 or so spare part.
  10. #25
    Jul 2007
    THE BIG SKY
    I take your point that a belt failure could cause significant and disabling damage. Changing as prescribed by BMW is what I have done and recommend. I thought the R12s do not use a HES ; am I misinformed?
    Kevin Huddy
  11. #26
    Jun 2008
    SF Bay Area
    On a 1200?
    Not sure about the camhead, but there wasn't much to damage on a hexhead.
    FWIW I changed mine at the '05 recommended intervals of 36000 miles. The one I took off always looked and felt about the same as the new belt that was going on the bike.
  12. #27
    May 2007
    Raleigh, NC
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
  13. #28
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    I like this video better. The head of the large adjustable wrench lifts and guides the belt on. No fancy single purpose tools needed. Worked fine on my GSA
    http://www.youtube.com/watch?v=YzPTPN98x40
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
  14. #29
    May 2007
    Raleigh, NC
    Yeah but that video uses no tool. I've replaced my belt twice, with no tool, and it NEVER went on that easy!
    '10 R12RT, R90/6
    Suzuki DR 350
  15. #30
    Mar 2004
    Alexandria, VA
    It takes seconds with a 12" Crescent wrench.
