Results 1 to 7 of 7
Thread: Schuberth & SRC vs Sena SMH-10
    Cowboyatheart
    Feb 2009
    Pender Harbour, B.C.
    Happy New Year to everyone - have a good new year's eve!
    I currently have a BMW System 5 helmet and Sena SMH10 communication device. I will be purchasing (as long as it fits properly) a Schuberth C3 Pro in the spring 2014, and I wanted to elicit comments and information/experiences from members of this forum regarding the quality of communications, connectivity, ease of use, etc of SMH10 vs SRC (Scala system).
    I find the SMH10 to work really well and it is easy to use. However, it seems a crime to hang this stuff off the Schuberth when they have a very nice integrated communication system (at least from a visual perspective).
    So, what are your experiences, comments, thoughts on the two systems?
    Moringa, your body & brain will thank you! PM for discounts Smart Mix at TasteMoringa.com
    XM3 Energy, real energy for the body & brain, no sugar high, XM3.Energy
    Cowboyatheart
    Feb 2009
    and info from Scala
    Thank you for contacting Cardo Systems Support Center regarding our products.
    The scala rider headsets use a 2.4ghz Bluetooth signal to maintain intercom communication.
    Please feel free to contact us if we can assist you with any other questions.
    Best Regards,
    Robert Wargo
    Technical Support
    Cardo Systems, Inc.
    Phone: +1 412.788.4533
    Fax: +1 412.788.0270
    Toll Free: +1 800.488.0363
    International: +49.894.503.6819
    robert@cardosystems.com
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    Perhaps the Sena SMH10R would suit your helmet better. It is very thin and should fit the contour of your C3 pro. Functionally it works the same as the SMH10.
    I will be holding out for the Sena 20s coming this spring. Longer range, intercom compatible with other Bluetooth systems, and FM radio are few of the advantages. It is narrower than the SMH10 but not as thin as the SMH10R. I have been happy with the SMH10 for over three years. The new model should be a nice upgrade.
    2014 R1200 GSA W
    2016 S1000XR
    Riding is the art of throwing yourself at the ground and missing
    Geeser mcover's Avatar
    Nov 2006
    Annapolis MD
    I rode with SENA for 5 years before going to the Scala this past summer. One of my New Years resolutions is to go back to SENA. I find it has better sound quality and longer battery life. And you can plug it in on the bike and use it while it is charging. I don't mind that it sort of spoils the look of the Shuberth.
    Marty
    K1600GTL
    F700GS
    IBA #42016
    Registered User kthflieger's Avatar
    Apr 2011
    Southeast Atlanta metro area
    there are a few other threads about the problems with Scala and their poor customer service...
    "Wer reitet so spaet durch nacht und wind -es ist der Vater mit seinem Kind" -- Goethe
    R1200RT, F800GS
    '80 GL1100
    Registered User gregcrna's Avatar
    Jun 2012
    Grand Rapids, MI
    Quote Originally Posted by nelliott View Post
    I purchased a Schuberth C3 and SCR System June 2012. The SRC is Cardo compatible. I don't believe the SRC is compatible with the SMH10 (but I'm not really sure!). The SRC unit is based on the Cardo Scala G4 system. So check with compatiblity with other units if you are hoping to communicate with others you ride with. I'm told the Schuberth unit is much quieter than others due to the communication unit integration with the collar on the helmet. I've only had/used this helmet. It is very easy to use and works well with my riding buddies. They have the Cardo Scala G9. (Scala G9x will be out before spring)...
    The SRC unit has a limited range due to its integration with the helmet collar. Thus no true external antenna. The new Schuberth C3 Pro has an antenna integrated in the helmet itself. So range will be increased somewhat. You will pay a premium for the SRC as it does work with a rather expensive helmet.
    The Cardo Units, mount clamped to the outside of the helmet and range is doubled.
    I haven't had any real issues with riding on highways and losing connections with the other riders. Riding in "deals gap" for instance, connections are lost due to interference from mountainous terrain, trees, twisties, etc. Line of sight is necessary for a good connection.
    Greg
    Registered User Royal Tiger's Avatar
    Dec 2013
    Lehigh Valley, PA
    I tried a bunch of bluetooth helmet to helmet communicators at a demo, and the best by far was the UClear. As a plus it is boomless, which a few others now have as well.
    ~Dan
    2013 Yamaha XT250 * 2012 Kawasaki Ninja 250 * 2007 BMW G650X XChallenge * 2007 BMW R1200ST * 2003 Yamaha PW80
