Results 1 to 3 of 3
Thread: R1100 Valve cover bolt seals
    Jun 2012
    Phoenix
    I need to remove the valve cover bolts from a damaged cover.
    How do you get the bolt sleeves/seal....out of the cover?
    Thanks. Ibjman
    . AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    I push them out from the inside with a blunt screwdriver. Just work around the bolt until it comes away from the cover, then maybe pull from the outside. Nothing special, no secret.
    Anton Largiader 72724
    largiader.com bmwra.org
    Bednarley
    Dec 2010
    Lake Norman, N.C.
    They're tight fitting on the bolt. I just replaced my head gaskets and they had gotten hard...so I ended up using wire cutters to cut them...but I was planning on replacing them anyway. If you're not replacing, it'll be a little tedious ...mine were the originals....
    Chip
    '94 R11RS
