Results 1 to 11 of 11
Thread: Hydration Suggestion
    Oct 2012
    2013 R1200RT Did my 6,000 service and stored the bike in my shed. Farkles: Darla lights, GPS, touring pegs, cylinder head covers, Givi top box and Hyperlites for the rear. Will send out the seats for RDL upgrades in January.
    Prepping for Iron Butt runs next year and am looking for suggestions on the best way to carry water to keep hydrated. Camelbak packs would be too hot over the armor.
    Any suggestions???
    Thank you all in advance.
    Camelback bladder in tank bag or Camelback mounted with your gear behind you.
    Always clear the hose by blowing into it after you are finished having a sip. The liquid in the hose warms up rapidly in the sunlight.
    Aug 2008
    North Carolina Coast
    Camelback . . . .
    I could not have done Bloomsburg without a Camelback. It is a must have!
    Campbell Tellman II
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    http://www.nmpcs.com/Bikes/R12RT/Hydration/
    I now have a stainless mount on the right footpeg. Much easier to pull the jug out and put it in and it stops the flopping around.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Feb 2009
    Mississauga, Ontario
    Excellent suggestion for location. I find it works well. Also, puff a little extra air in the Camelback just before drinking and you get a slight pressure feed on the water.
    Walter
    H. L. Mencken
    Registered User peterbonly's Avatar
    Dec 2004
    Linda T
    My LD bike was outfitted by Linda T who makes anything you want for your bike. Check 'bike cover' along the left side of this link: http://customtankbags.com/ .
    Picture the small bag it fits into attached to the left side passenger peg; on the right passenger peg is my hydration system - it consists of a fabric 'holder' with a retaining strap that a 1gal thermos fits into. I added my own tubing that is easy to disconnect when it is time to refill. Simply carry it in to the store, add ice, buy water and the ice is usually free; put the top back on it; place it in the holder and attach strap - your good to go.
    The two items are kept on the bike with the peg straps and 2 other straps that go under the seats and connect to each other. They are totally out of your way.
    -pp Long Distance Motorcycle Adventurer
    '00 GS w/ >165K miles; '07 RT w/ 160K miles - for sale; '12 K1600 GT 6k miles
    LD blog: www.ppldma.com
    Mar 2007
    Chicago, Ill
    I fill my Camelback with Ice -
    More accurately I go into a Fast Food place and order a self serve beverage. I avail myself to the ice machine, fill the bladder with Ice, and usually add either tea or lemonaide - both of which mix well together. Rather than being hot, I now have a cool/cold spot on my back..and this worked even in Moab, Utah in July with 104 degree weather.
    Of course you need to repeat this procedure every couple of hours.
    Aug 2005
    Charlotte, NC
    +1
    works for me too!
    Quote Originally Posted by Beemer01 View Post
    Enjoying the ride, but always on the alert for a rally.......
    RT in NC
    Jun 2013
    My badlands jacket has a pouch for a hydration bag. I needed to take the back protection pad out to make it comfortable. Plus I may have overfilled the bag.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic
    143439 bobr9's Avatar
    Jun 2012
    Clarkesville, GA
    I did the same thing last year on cross country trip out to rally. Only difference is I used a geigerrig hydration pack, which is pressurized so it is easy to clear out any warm water in the line. Check it out at www.geigerrig.com. Neatest thing since sliced bread. I have the 70 oz capacity model.
    Registered User frenchnew's Avatar
    May 2011
    Prevost (30 miles north of Montreal), Quebec, Canada
    When I prepared for the rally last year, I purhcased a 70 oz Geigerrig engine and also a 13" laptop neoprene bag and also use plastic bubble packing material with aluminium foil on one side. Onece the geigerrig filled with ice and covered with one layer of plastic bubble pack and inserted in the laptop neoprene bag, the water remained cold for over 6 hours in over 100 degrees F.
    This made my over 6,000 mile s trip in 12 days easy in the hot weather.
    2011 R1200RT Triple Gray, ABS, ASC, ESAII, TPMS & Alarm.
    Wunderlich Engine and Rear Prot. Bar, Oil Cooler Guard, CSS Tank Pads, Paralever Slider, Mirror Adapters & Flash Mirrors,
    Integrated GPS Mount & Touratech Zumo 660 Locking Mount, Russell Day-Long Seat.
