Results 1 to 15 of 28
Thread: valve inspection / adjustment 2013 F800GS
    I'm new to riding and owning a quality motorcycle so please forgive my ignorance. Why must I have the valves inspected and if necessary adjusted every 12000 miles? I ride a 2013 F700GS and am very pleased overall with it but a little surprised at the upcoming service cost. My 4 wheelers don't need this and last forever and some motorcycles don't need this. Also, what would happen (in theory) if this service was ignored? Thanks for your consideration of this topic.
    Jul 2007
    THE BIG SKY
    Hello NewRider, Welcome to the forum.
    Your car likely has self-adjusting hydraulic valves; your 700GS has a much different arrangement. To follow or not follow the maintenance schedule is a personal decision, but many check the valves far less frequently on the 800 cc engines. I waited until over 24,000 miles before I had them checked on Annie's 650GS and they were in spec. Over on the http://f800riders.org/forum/forum.php there are many stories of folks going long past the scheduled checks with no problems. There are also some who did need an adjustment at 12,000. It is probably smart to have them checked at 12k or soon there after. If they are in spec or adjusted to be in spec, then IMHO it is probably ok to expand the interval to every 24k. Be aware of the signs of out of adjustment valves such as hard starting and excessive popping or backfiring on deceleration. The most likely serious result of riding with the valves out of adjustment is a burnt valve, and that would be very unpleasant. There are some better wrenches than I who will offer you advice I'm certain, but that's my take.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    Most cars have hydraulically self adjusting valves. Those that aren't require adjustment eventually.
    Why? As the valve slams closed thousands of times per second, the mating surface wears. Very slowing on the intake valve which gets cool fuel and air, but more rapidly on the exhaust valve, which has flaming fuel passing through it when it opens. As the valve and valve seat wear, the valve stem moves up removing the clearance between the valve and cam or rocker arm. Once that clearance is gone, the valve will not close completely and burning fuel will leak out during combustion eating away the valve and valve seat. Eventually, this will destroy the cylinder head and valves, costing a LOT to fix. If kept in adjustment, the valve train can last for a couple hundred thousand miles.
    See picture here (I did not embed it because it is not my picture):
    http://lkn4drt.smugmug.com/photos/463654461_Q3Duo-L.jpg
    Hope this clears things up.
    1988 K75 Low Seat
    2009 R1200R Roadster
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    Understood, but the follow-up question is: why don't m-c manufacturers use hydraulic valves? There are some but the design is not widely employed. On touring/adventure type bikes it would be/should be a given. I owned a Honda CB700SC some years ago that redlined over 10,000 RPM and it had hydraulic valves that worked perfectly and lasted forever, so it can be done. Why not on a K1600 or F800?
    And BTW, I just had the 12K service on my camhead RT and the valves were in-spec.
    pete
    2011 R12RT
    Norm Norms 427's Avatar
    Nov 2011
    Spokane, WA
    Fortunately it's not very hard or complicated to check and adjust the valves on our RTs. Just look at some threads on this forum and dive in … the water is fine. You'll be proud of yourself for accomplishing the task ... and save $$.
    I wish more manufacturers would employ hydraulically actuated valves, at least in their lower revving motors. I do appreciate that my Harleys are hydraulic w no adjustments needed.
    Now: '12 R1200RT Midnight Blue Metallic / '11 Ural Patrol 2WD ridden to Alaska / '09 KLR 650 / '05 HD Heritage Softail / '08 Harley Sportster 1200C / '85 Yamaha VMax bought new. I wasn't ready to say goodbye: www.shaunlunt.typepad.com
    Minnesota Nice! braddog's Avatar
    Twin Cities - MN
    Quote Originally Posted by na1g View Post
    pete
    2011 R12RT
    Actually, several manufacturers do use hydraulic lifters/valves. One that comes to mind is Harley-Davidson, you know the American company that sells outdated motorcycles to wannabe pirates. (tongue FIRMLY in cheek).
    Brad D. - Member #105766
    '77 R100RS - Black Beauty (big pipe, baby!)
    '94 R1100RS - Sylvia
    Apr 2006
    the type of system the F700/800 uses is pretty stable, I think 12K is probably overkill. Bunch of posts on ADV rider claiming still good at 40K +.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Jul 2007
    THE BIG SKY
    Quote Originally Posted by pffog View Post
    My FJR is similar I believe and the service interval is 26K. On the FJR forums it appears that many owners go 50K between checks.
    Kevin Huddy
    Jun 2007
    Portsmouth, NH
    I'd guess that any shimmed valve adjustment system will be very stable after the initial adjustments. I'd still check them at the prescribed intervals though.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by Anyname View Post
    Not entirely true. It's not the adjustment method that is the main issue. Tiny Trains explanation is right on.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Mar 2013
    Winnipeg, MB, Canada
    I would assume that was true as well.
    At a time in my career, we took delivery of 35 trucks with engines from a very well respected engine manufacturer. After a couple oil changes, maybe close to 20,000 miles, every operator complained of low horsepower and high fuel consumption. These are engines designed to run 2,000,000 miles and they could with good TLC.
    We resolved the problem with valve sets.
    Every engine I build, I include a valve set in my price. I like to see them at about 5,000 miles.
    That being said, opinions can vary and are valuable for perspective and I may be a bit outdated with the specifics of the newer engines but I believe valve sets after break-in are worthwhile.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    Apr 2008
    SW Ohio
    Quote Originally Posted by tinytrains View Post
    As the valve slams closed thousands of times per second....
    Just to nitpic, say at 9,000rpm, a valve cycles 4,500 times per minute in a 4 cycle engine. 4,500 divided by 60 seconds is only is 75 times per second! Still pretty hard to visualize all that going on down there.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Oct 2009
    Torrance CA
    [QUOTE=na1g;911755]Understood, but the follow-up question is: why don't m-c manufacturers use hydraulic valves? /QUOTE]
    Because the motorcycle world mostly wants to go fast and don't seem to care about maintenance complexities or costs.
    Hydraulic lifters take up space, add complexity and tend to have several problems on high RPM engines. First, is increased valve train mass. A rocker arm is required which adds mass, and results in valve float at high RPMs. Especially with radical cam profiles on sport bikes. Second, lifters are prone to pump up. They can over pressurize at high RPMs causing the valves to not fully close. Third, the cam over bucket design works really well and is easy to make. Companies have built low maintenance motorcycles over the years, and with the exception of touring bikes and crusers, they don't sell well.
    I bought a R1200R boxer because I can maintain it myself. Valve adjustments on the modern K-bikes are way more than I want to deal with or pay for.
    1988 K75 Low Seat
    thanks
    thanks everyone for your feedback. I probably will spend the big $$ soon for the 12K service and then wait until 35999 for the next inspection. I understand the MC engineering logic for BMW's valve design - higher RPM and thus higher HP, marketing purposes. Can you imagine a quality MC manufacturer like BMW selling a mid size bike that the owner could do ALL maintenance? What an advantage. I can't even change the spark plugs (they tell me) without a special tool. My son had a 1983 Honda Shadow 750 shaft drive, hydralic valves and you could change plugs easily. The bike ran great, almost the same mpg as my 700gs on a long fast road trip and It ran on regular gas. I wonder what it costs for a K1600 plug change and valve inspection? Are the R engines really that easy?
    Spring Lake NJ, USA
    Hi folks,
    Great discussion.. I'm moving it to the F-twin's forum since it really fits there a bit more, especially since the question initially asked was about service on the specific model.
    Hang on while it's moved (and please keep hands and feet inside the thread until it fully stops moving..)
