I found lower edge of the C3 to be too thick to use the Sena SMH-10 clamp mount. I'm using the adhesive mount, placed as far forward as possible. I've not felt the need to screw it in place as the mount seems to be solid. I ran the wires between the neck roll and the shell. Currently I'm using the wired mike stuck to the chin bar - the cord usually needs to be pushed to the side after I close the bar, sometimes a nuisance. I may try using the boom mike as Akbeemer described or try extending the wire on the wired mike so it can be routed closer to the hinge point of the chin bar. Somewhere I read of putting the wired mike on the front of the cheek pad (by the Schuberth label), but I'm not confident this position would work well.
