Results 1 to 10 of 10
Thread: Booster Plug...anyone have one on a F650cs?
    Dec 2011
    East Troy, WI
    I keep seeing the add for a booster plug.
    http://www.boosterplug.com/shop/boos...50cs-216p.html
    Has anyone tried one on a 2005 f650cs?
    Diamondhead, MS
    Why do you think you need one ?
    Dec 2011
    East Troy, WI
    That is a solid question!
    I was just curious. Is much as I am told my 2 spark is supposed to be smooth I do still feel it is a touch surgy at slower speeds. Maybe it would iron out some little wrinkles? Has any one tried one?
    Diamondhead, MS
    I don't have experience with one; nor do I have a twin spark. If iy works like the techlusion units, the results vary. Your fuel economy will probably suffer as most of these units work by convincing the computer that a richer mixture is needed. Most, if not all, post 2000 bikes have been leaned way down by the manufacturers to better comply with EPA regs.
    Jul 2007
    Charleston SC
    Booster Plug Installed
    Quote Originally Posted by acejones View Post
    I have an 03 F650 CS, single spark, fuel injected, after installing it the throttle response was smoother, got ride of the surging problems. My fuel economy went up by 2 mpg. I think this is because the throttle response is not jumpy anymore, smoother on and off the throttle. The performance improvement was noticeable.
    Put one on my wife's '03 650 GS last year, I always was bothered by the borderline lean surge, and lack of throttle response due to the lean conditions. It made a noticeable difference, and didn't hurt the mileage at all. I actually enjoy riding her bike now.
    This is the same thing as the "booster" and the one i used for $75, http://www.wukaking.com/home.html
    Put one on my '10 F800GS too, big improvement on the jerky throttle response.
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    The "booster plug" industry has been around longer than you may think.
    Back in the '70s I ordered a kit for my Opel Manta. I received ...
    larger main jet
    Softer distributor advance spring
    Jul 2007
    Charleston SC
    After 2K miles on Bike
    I installed the Booster Plug and have put 2K miles on it now. For all that people that thinks this is smoke and mirrors it is not. The enjoyment this has given me is priceless. The bike is a changed performance machine. I cannot believe the difference in starting, throttle response and not a hint of surging.
    Registered User Rob.rautenstrauch's Avatar
    Jan 2014
    East Amherst, NY
    It works
    I put one on my 02 F650GS. It definitely helps with low end surging, smoother throttle.
    Wilmington, NC
    When EGR first showed up in the 70s the std drill to get performance back was to install faster advance springs (distributors were still mechanical with points except on some Mopars), advance timing as far as one could get away with without knock under load, and richen the fuel mixtures- simple jet changes in the carb or sometimes a new carb with a better accelerator pump- judged by the now mostly irrelevant and arcane art of reading plugs (not nearly as easy to do well for tuning purposes as some think)
    I once modded a 6 cyl, auto tranny Duster to the point it would smoke its tires from a standing start just by toeing the pedal- of course we didn't have today's radials either.
    Now if you hope to accomplish anything you better understand sensor controlled injection systems and be ready to play with electronics. The tradeoff is that if you're willing to use all of today's tools you can alter anything or everything. There's a different problem today- a lot of today's stuff is made in a way the altering it to substantially to increase airflow is difficult and/or expensive (without boost)- and with engines being air pumps, that's the fundamental thing that has to happen if you want a bunch more power.
    Fixing driveability is a lot simpler, fortunately. But it has been clearly show that the adaptives in both the Motronic and BMS-K engine management computers give priority to the oxygen sensor (as would be expected) and also adapt to the presence of changes directed at the other sensors over time. The effects of items altering other sensors will be greatest at installation and will be altered to an unpredictable extent over time.
    The shortcut to increasing power a lot today is boost- turbo or supercharger. Air flow increases (and therefore power increases) of 30-100% are easily done, depending on the base motor. All on street gas.
