Results 1 to 10 of 10
Thread: Front Fork Brace
    Registered User rapz's Avatar
    Nov 2003
    Mission, TX
    Front Fork Brace
    I'm switching out my ATE brakes to the Bosch brakes on my '79 RT and I don't really know the year of the newer lowers but they are different than the ATE lowers. I don't know the year on the Bosch lowers, but would like to know what fork brace might fit. Is there a generic size brace for the lowers? I figure it has to be an early 80's set of lowers, but can't be sure. Appreciate any recommendations.
    Website: www.airheadmoto.com
    IBA No. 58411
    Current Bike 1979 BMW 100RT; 2013 BMW R1200RT 90th Anniversary Edition; 2008 Harley Davidson Ultra Classic 105th Anniversary Edition
    Administrator 20774's Avatar
    Bosch? Brembos, right?
    Albuquerque, NM
    The switch to Brembo front brakes and handlebar mounted master cylinder occurred for 1981 model year. You can source parts from '81-'84 models only, as it changed again for 1985 and isn't backwards compatible from then on. Look for fork brace compatible with '81-'84 models.
    Kent Christensen
    21482
    Sep 2013
    central Illinois
    You may discover that the holes for the fender mount may not line up correctly on your '79 fender.
    Nov 2003
    Mission, TX
    Yes, sorry, it is Brembo Brakes. Thanks for the information. I'll look for the '81 to '84 compatible fork brace.
    IBA No. 58411
    Nov 2003
    Mission, TX
    Quote Originally Posted by James.A View Post
    Once I get the bike on the highway to evaluate the switch and if I stay with the Brembo setup then I'll get a body guy to retro fit the fender unless I can find one. I hate to change it and may leave it. I'm still debating with myself to leave it "as is" with that tall narrow fairing and lowers or just make a cafe racer out of it.
    IBA No. 58411
    Fender braces for Brembo brake fronts are fairly common
    You may find some OEM braces in the flea market right here or that IBMW may have the one you need if you stick with Brembo's. While your at it you may think about getting some stainless brakelines as well.
    Nov 2003
    Mission, TX
    Quote Originally Posted by 69zeff65 View Post
    I haven't changed out the 'under the tank' master cylinder to the one on the handle bars. I know that isn't as much pressure as I need, but I wanted to hold off on that switch until I make the final decision on the Brembo calipers.
    IBA No. 58411
    Aug 2013
    Camas, WA
    Go to the handlebar mounted master; I'm doing that with my ATE's this winter. The under-tank setup is ridiculous! (They did it why? Because earlier drum-braked models had clean bars??)
    I just upgraded my Yamaha FJ1200 to R-1 brakes, what an improvement! Brake upgrades are something I think everyone should work at, because modern traffic doesn't care what your original brakes could do.
    Nov 2003
    Mission, TX
    Good point!
    IBA No. 58411
