Results 1 to 5 of 5
Thread: K100 1986 Digital gear indicator
    The gear indicator is showing #4 in neutral and #5 in first and the neutral green light does not come on in neutral or any other time.
    The LCD clock is also not working. This is a machine that I bought because it has low mileage 40000KM and had not run since 2009.The bike will be on the road this coming spring. Is there a fix or what parts need changing. I also drive a R100RT and like the idea of a gear indicator.
    Thanks Bob
    Astatula, FL
    Quote Originally Posted by Bob 1642 View Post
    Thanks Bob
    Look here.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Apr 2005
    Rapid City South Dakota
    I had a similar experience with an 85 K100 that had some storage time on it. I read the Curry article and purchased a new switch. On removing the switch it appeared to be solid and after installing the new switch the problem remained. I then read all I could find on the instrument cluster because the speedo was flacky and proceeded to clean all the connections inside and out of the cluster. Including the LCD chips of the gear indicator and the clock. I used a pencil erasure where I could and used a tooth pick with a very very small amount of anticease on the pin connections. Now three people will chime in and say that was the wrong way to clean them but it worked and has for 6 years. Harold in Kansas
    Harold In Rapid City, SD
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
    The instrument cluster does seem to have had a moisture problem as I see a rusty screw inside the glass and some one has drilled 4 holes in the back of the case to vent it. I will open the cluster up and have a look and clean up any water damage corrosion.
    Thanks for all the info.
    Cheers Bob
    Registered User robsara's Avatar
    Dec 2009
    West Michigan
    Mine did the same, I didn't have the moisture issues, but the switch needed a good cleaning and rebuild. It has worked great ever since.
    Rob R
    1994 K75 My first bike.
