Results 16 to 17 of 17
Thread: '93 K75 RT-P Starter Issues
    As for the original noise heard by the OP - there are at least two, maybe three bearings inside the auxiliary case that could be making noise.
    Paul,
    The "auxiliary case" is the case holding the counter balancer?
    Guess hat means I've got to pull it apart again. :-(
    BTW, in another thread it was mentioned that you had written a column dealing with starter sprag clutches. I was unable to find it. Has BMWMOA archived your tech articles? If not, they should!
    Astatula, FL
    Quote Originally Posted by wchoar View Post
    Paul,
    Sprag clutch, look here.
    Bob Weis
    '04 K12RS - Hannigan Hack
