Results 1 to 7 of 7
Thread: Headlight Adjustment Knob (R1150RT 2004)
    Bill Lumberg 175781's Avatar
    Dec 2011
    Noticed headlight was tracking a little high, which was odd and unrelated to load. Reached in to adjust (dash knob was already at lowest setting), and the gray plastic nut fell off. Try as I might, I haven't been able to reattach it to the white receptacle it detached from. Advice? Bike is quite driveable, but my headlight is aimed somewhere into the wild blue yonder. Thanks.
    R75/6, 2004 R1150RTA.
    Registered User kioolt's Avatar
    Maryland
    I recently had my dash off to do some work which required me to remove the headlight adjustment knob. I seem to remember that the knob is not in a receptacle but is on a shaft that required me to loosen a screw to get it off.
    Can you take a picture of what you have? I believe that you have something that is broke.
    2004 R1150RT 164,500 miles , 1991 K100LT 128,500 miles, 1982 R100RT 106,900 miles
    Total 399,900 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Dec 2011
    It's not the dash adjustment knob that fell off, but the main nut on the headlight assembly that it engages. Knob.jpg
    Albuquerque, NM
    That's bad, as with all BMWs, headlights are a supplier sourced item and there are NEVER any spare parts in the BMW parts system. Most problems are with bulb retention clips (not available separately) but yours is a cautionary tale as well.
    Kent Christensen
    21482
    Dec 2011
    I have all the parts, and this looks like a press-on item, but I'm not sure. Everything is an adventure for someone mechanically disinclined like me.
    Mar 2013
    Winnipeg, MB, Canada
    Can you retro-fit to an 1100RT?
    I had an old oilhead with a Luftmeister fairing, I miss that bike.........................It had a headlight adjusting knob. I wonder if you could retro-fit an adjuster to my 1997 R1100RT?
    I have all winter to try. It's snowing pretty good right now so I think the season is over.
    3xR90/6, one running most excellent, two for restoration.
    1983(?) K100RS for winter project, 1986 K75S(the beutch)sold, 1993 K1100RS (blown engine)sold,
