Results 1 to 7 of 7
Thread: 1992 K75S w ABS Mirrors
    Registered User heejrbmw's Avatar
    Aug 2009
    Boone, NC (Mountains of Western North Carolina)
    I'm interested in finding a set of mirrors for my new to me 1992 K75S. I cannot adjust the stock mirrors sufficiently to see behind me. I either need a different shape, different/longer mirror shaft, or both. Does anyone else have a problem with this, and if so, have you found an suitable/good alternatives?
    Ed
    Ed Evans - - Semper Fi
    '94 K75 '92 K75S
    "Always do more than expected." Coach Jerry Moore, ASU
    Jun 2012
    Olympia, WA
    Did you loosen the nut on the bottom of the mirror post and pivot the whole mirror assembly?
    Aug 2009
    Quote Originally Posted by timtyler View Post
    I did loosen the nut. I still can't adjust enough to see behind me as well as I would like to see. I'm not tall, so I probably sit more forward on the seat than some do, making me closer to the mirrors and harder to see around myself.
    '94 K75 '92 K75S
    Spring Lake NJ, USA
    Try buying two of the little bulls-eye round mirrors - the ones about 1.5" diameter work great. Put them at the very top of the mirror glass, then adjust the regular mirrors so they look to the sides of the bike, not behind it. You'll find the bulls-eye mirrors provide plenty of info on what's going on behind you - plus they cover your blind spots on the sides.
    BTDT - now I've done it to every bike I owned.
    Registered User argent brick's Avatar
    Aug 2012
    Wine Country, Northern California
    I have never seen K bike style mirrors on any boxer but, it is my understanding that BMW used the same basic mirror on one of the R bikes for a short period of time. The only difference was a little longer stem than the K bike version. This would effectively put your mirrors out farther. I would guess that cost should be about $45-50 bucks per mirror if purchased new.
    If this information is correct, then, in theory, the older style mirrors that were used on the the airheads might also work. I can tell you that they offer two different mirrors that fit on the old /6 and /7 boxers. I swapped short for long mirrors on my R60/6. Worked very well. I don't have any part numbers for you, sorry.
    Give Beemer Bone Yard a call. Maybe they can help.
    Lynn
    MOA #57883
    Current Ride: 1995 K75 Standard
    Past: 1978 Yamaha XS 750, 1976 BMW R60/6
    Registered User darrell's Avatar
    May 2005
    Minnesota
    Updated Mirrors
    I installed the mirrors from the R1100GS on my K75S as they had 2" longer stems pushing them out further. I got mine from MaxBMW. Any dealer should be able to order them or you might be able to advertise for a used set.
    Darrell
    Darrell
    Aug 2009
    Quote Originally Posted by darrell View Post
    I installed the mirrors from the R1100GS on my K75S.
    Darrell
    Thanks. I looked at these and they will probably be better. However, I'm holding out a little while longer hoping to find some type of rectangular mirror.
    Ed
    '94 K75 '92 K75S
