Results 1 to 7 of 7
Thread: 86 R80 RT Dead
    86 R80 RT Dead
    Well, not completely, the clock still works sort of.
    Wanted to go for a little ride this afternoon, and when I tried to start the bike it cranked about one turn and died. All lights on the panel out, no power to be found.
    Battery checked good, but with a slightly loose cable. Tightened the cable to no effect.
    The clock works with the switch off, but stops in the first and second positions. When I wiggle the key, I am occasionally able to get a glow in the indicator lights on the panel, but the bike will not crank. The parking light has come on, but no headlight. As of this moment, no panel or parking lights work.
    Is the answer the obvious one: failed ignition switch? Or, is there more I need to be looking into? Can anyone tell me how to jump over the switch?
    All suggestions appreciated.
    Zimm
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    How do you know the battery is "GOOD"? With a VOM a battery will show 12V but as soon as you put a load on it, like even just a turn signal bulb, it goes dead.........SO......the first thing to do is to be sure your battery is good...........Try jumping, hooking up a battery from a system or whatever that does turn over an engine......car or whatever. Perhaps you have a charger with a "boost" function to use to "jump" and charge with.........
    I am sure there will be more from others; but be totally positive that the battery is REALLY GOOD and that all connections are in order. Ground down at the transmission and on the battery itself...........God bless........Dennis
    Mar 2008
    DeLand Florida
    Dennis is right. A break in the internal bus of the battery will often pass voltage, but not enough current to do much more than light a small bulb. If you do not have a load tester, use the bike as the load tester. Hook the DVM up to the battery TERMINALS with key off, then turn it on. The lights should come and the voltage will drop a volt or so in a minute or two. I bet yours drop much more (maybe all the way) from your description, if it does the battery is toast. If it does not drop much, move the DVM to the WIRES or LUGS connected to the battery and repeat the tests. If you had good voltage on the battery terminals, but not the lugs, they need cleaning.
    Wayne
    More info
    Looking some more, I think you are correct that the battery is bad. Its an off brand from China of unknown vintage (I pulled it out).
    Using a meter, it shows 12.5 volts. I get the same at the switch. When the switch is turned on, voltage drops to about 3.5.
    I've had lots of batteries die on me over the years, but must confess that this is the first one that did so mid crank.
    I'll go by the battery store tomorrow and have them test it, that will tell for sure.
    Suggestions as to a good replacement are welcome.
    Zimm
    Mar 2008
    DeLand Florida
    Glad you have your problem figured out. Odyssey is a great battery, Westco is another one. If my memory serves me right the R80RT (my first BMW was a new 86 R80RT) takes a smaller battery than the R100's, but the bigger battery will fit if you remove the tool box that came in the bike and install one from an R100.
    Wayne
    Sugar Valley, Ga
    +1 on the Westco........I have had one in my machine now for 6 years with the only maintenance being to put a tender on it during the winter for a couple of weeks at a time..........I use horse stall mat, rubber perhaps 1/2 inch thick that I cut to meet the dimension I need to make up any size difference......The stuff is black, durable, and just rubbery enough to absorb some vibes........Anyway.....Glad you got it figured out. They should all be that easy.........God bless........Dennis
    Mar 2010
    Vancouver, B.C. Canada
    I have an Odyssey PC680 in my R80G/S and it fits perfectly. You do have to remove the upper shock bolt to get it in there though. I've had a Panasonic LC-X1228P in my R100RS and it is narrower than the stock battery. It has been in the bike for six seasons now but is nearing end of life. Still, good service I think. You should check dimensions for the R80RT though. It might be a bit big.
