Results 1 to 9 of 9
Thread: 1995 k75 fuel filter
    Registered User DENKAR55's Avatar
    Sep 2010
    Scottsdale, Arizona
    I recently bought a K75. It resides in Germany.
    I wanted to change the fuel filter. I just recently ordered a workshop book for it.
    My question is......
    Is the changing of the filter involve removing the tank or ?
    Dennis
    2012 R1200RT
    1995 K75
    Dennis and Karin Trovato
    2005 BMW R1200GS (In Germany) //// 2015 BMW R1200GS Adventure (In USA)
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    You can remove the gas cap assembly and just reach in.
    It helps if the gas level is low.
    Lee 2011 K1300S
    MOA # 30878
    Past BMW Bikes, 2003 K1200RS, 1991 K75S, 1987 K75T, 1984 R100RT
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    No. No need to remove tank.
    Remove 4 screws that hold the fuel filler cap and neck to the tank.
    Cover top of tank with a couple layers of towels to prevent getting any drips of fuel on the paint.
    Loosen hose clamp on the short hose on the end opposite the filter. A LONG screw driver really helps (one hand in tank holding clamp and screwdriver tip. The other hand outside the tank turning the screw diver).
    Lift filter and hoses out of tank.
    Remove long hose from filter.
    Transfer short hose to new filter. Make sure arrow on filter points toward short hose.
    Reinstall.
    It helps to put a reference as to what the thread is about in the title. I've added that info for you.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    May 2003
    SW Iowa
    You might want to change the year of the bike
    Lee 2011 K1300S
    MOA # 30878
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    I just thought it was one of the REALLY early ones. That would be the kickstart, drum braked, carbureted ones.
    Mine, Hers, Spare
    Sep 2010
    Scottsdale, Arizona
    Thanks!
    Thanks very much. Your directions and information will be very helpful. Thank you for your time and knowledge..
    Dennis
    Reinstall.
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    The BMW filter is about $25. I found a filter that looks exactly the same it at Autozone for $4. I have been using them for years with no problem. Just be careful to the the right nipple size. Sorry, I do not have a part number.
    1988 K75 Low Seat
    2009 R1200R Roadster
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Be very careful.
    Some "identical looking" filters don't have the burst pressure rating or the correct micronic filtration required for fuel injected motors.
    Some of the cheaper filters have less filtration capacity (less square inches of filter paper inside) and will plug up quicker).
    IF you are going to substitute parts, research the specifications first. Just because the can on the outside is the same size and shape does not guarantee that it will meet the same specs.
    Mine, Hers, Spare
    Apr 2012
    Los Angeles, CA
    Just adding one small tip to Lee's excellent description: assuming your machine still has the original hose clamps, they're 7mm screw heads. A 7mm socket on a screwdriver handle, or on a thumb roller, or both, makes this task waaaay easy.
    Just for completeness: Everything in there is 7mm, except one of the two nuts on the fuel pump, which is 8mm. If you're going to be maintaining the bike yourself, you may be in there more than you think, and adding 7mm and 8mm nut drivers to your toolbox is well worth it.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
